Question about Invicta Watches
I need the owner's/instruction manual for Invicta model #6155, a Venom with the ETA E20.321 and-digi movement
4 Suggested Answers
  • 3 Answers
SOURCE: how to remove links from invicta venom steel
on the small links, pop out the pin, either way, doesn't matter, then remove the bar sections (outer ingot looking part of link) by pushing the link inward toward where your wrist would be. The center scale looking piece will remain.
Then remove the sleeve which is slightly bigger in diameter than the pin, which is still connecting the center scale piece. I'll upload pix if anyone needs.
to put back together just reverse it. match up the two connecting center scale pieces, then insert the sleeve into them to connect them, then pop the ingot piece in from the center (where your wrist would be) then carefully slide in the pin, it should go halfway before you feel resistance, then carefully drive it home.
I think it will work with the bigger pieces as well, but didn't try, didn't need to remove any.
Posted on May 25, 2010
  • 3 Answers
SOURCE: How do you remove the links from an invicta
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Posted on Jun 11, 2010
SOURCE: I have an Invicta Venom
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Posted on Oct 14, 2011
Invicta minute repeater 2731 watch manual
Try the manuals for either the Bulova or Citizen equivalents, as both probably share the same movement.
Nov 23, 2011 | Invicta Watches
Where I can download manual for Invicta 2732 watches
Download a copy of that Instruction Manual ->click HERE
May 02, 2011 | Watches
How can I get the invicta model 2144 manual
Follow this link:http://www.invictawatch.com/ Hover over the COLLECTIONS tab and click on INSTRUCTION MANUAL. There you will see RONDA and MIYOTA movement tabs. Those are two manufacturers of watch movements used to produce all INVICTA watches. RONDA is Swiss company and MIYOTA is Japanese. Check out both to find an exact match to your particular watch.Unfortunately that is all Invicta can offer. Rate me please.
Feb 27, 2011 | Invicta Lupah 2144 Wrist Watch
Need a new watch movement
I am not sure which Vincente model you have but I can tell you that the movements for those are Swiss made. That may not seem like much but there's not a lot of info on them.
Chances are it's an ETA movement and if not there's an ETA movement that should fit it. ETA is one of the top Swiss movement makers around. You will find their movements in more watch over $1500 then I care to mention. You should be able to get a movement for around $150 plus installation. You will need to go to a watch repair shop so find a good one.
Hope this helps.
Jan 10, 2010 | Vicence Watches
Need a manual for an Invicta Minute Repeater Perp. Calendar #2731
The only site for Invicta watches is here:
www.invictawatches.com
You have to submit all the details of your watch and then you may find out manual.
You can download manuals for different movements used by Invicta.
You can contact them to get the needed info.
Do not forget to rate, please.
Jan 22, 2009 | Bulova Watch
Watches Logo
59 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
