Question about Mad Catz Bluetooth Headset for PS3
When i plug it in my ps3 the red light comes on but it only stays on for 3 seconds and plus i hear this beeping sound in it i really need help
  • 132 Answers
The beeping is a battery low error.
It is quite possible that the small battery inside of the headset has worn out, will no longer carry a charge and requires replacing!
Posted on Mar 16, 2011
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
My ps3 slim 320 GB wont stay on. red light comes
You have a mother board failure and your system needs to be serviced.
Aug 29, 2013 | Sony Playstation 3 (PS3) Console
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
It says improper shut down then freezes up and turns itself off
First make sure your PS3 is powered off and unplugged.
1. Plug your PS3 in.
2. Now hold you power button on the ps3 down, you will hear one beep, followed by another 5 seconds later, and a third one 5 seconds after that. After that the PS3 power light will turn red. You can now let go of the button.
3. Hold your power button down again, you will hear one beap, followed by another beep 5 seconds later, and then you will hear a double beep 5 seconds after that. After you hear the double beep, let go of the power button.
4. Now some words will come up on the screen saying to connect your controller.
5. You must connect your USB cord to your ps3 and connect the other end to your controller.
6. A selection menu will now appear.
7. Select the option "3. Restore File System" and press X.
8. Now follow the on screen dialog and once the restoration has completed your PS3 will be back to normal.
Please note: Following this guide will leave your Game Data and Save Files intact, you do not need to worry about this process deleting your Save Files or any other data. Your ps3 will be just like it was before it messed up.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up and everything it comes on but it won't come up on my tv screen, BUT EVERYTHING IS HOOKED UP, The hdmi cable is plugged in to
Please do the following steps to reset your PS3 display :-
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Wait for the PS3 to detect your HDMI cable.
Hope this helps and thank you for using FixYa
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
Moved playstation to friends tv played fine. Connected back to my tv power lights come on but No sound or picture yet all cables are ok
You need to reset the display, follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start up with normal display settings. If you are using HDMI make sure only the HDMI cable is connected when doing the above steps.
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is not working because when i plug in all the leads the picture or sound does not work so i bought a new cable but it still does not work I think it may be because i plugged it in to a hd tv then...
Ok, please follow these steps :
Step 2. Press and hold the power button. It will beep once when you first press it then beep again 5 seconds later, let go of the power button when you hear this second beep
Step 3. Wait for the PS3 to restart
This basically resets the video output back to standard definition where you should now be able to set it up properly.
Hope this helps
Sep 26, 2010 | Sony Playstation 3 (PS3) Console
PS3 stopped during play, now won't stay on.
Press and Hold your PS3 power button for at least 6 seconds and see if it beeps twice.... Make sure you have your composite jacks(Red, White, Yellow) hooked up to your PS3 and TV in order to see diplay and hear sound.
This will reset your PS3, but you will still keep all your data!
Good Luck!
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
There is no display
Hi there, what you need to do is reset the video display. Do this by following steps :-
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up.
Hope this helps
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Mad Catz Bluetooth Headset for PS3 Logo
467 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
Robert Little
Level 1 Expert
Dave
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
