Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Model: 52725 we hooked an xbox to this thing and it wont give us a clean picture, rather black and white fuzzies and has green lines shooting across the screen, sometimes purple going across the screen diagnally. It was much worse until we used the hdmi connection in the back of the tv but its still driving everyone nuts. I havent a clue how to fix this, is it even fixable? Please help. S.B.
    Problem Solver:
  • 9 Answers
There are small surface mounted capacitors on the dm Board and the fmt board that have gone bad. They need to be replaced. Most tv techs will charge about $400 to do this.
Posted on Mar 19, 2011
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
White wavy lines going across my t.v
LG 26LX1D
Symptom
Wavy lines in picture
Repair
Replaced 2 bad capacitor's on the main board Location's C704 C708 1000uf 16V
http://tvrepairhelp.webs.com/lgjvc.htm
Dec 08, 2011 | LG 26LX1D 26 in. LCD HDTV
Hello. I have the HDTV ready hookup for my xbox so all i have to do is switch it from tv to HDTV and it will switch over. My hookup has a green, blue, 2 red, 2 white, and a yellow hookup. i hooked in all...
pay attention on how you hook them into the xbox..and if you are sure this is the way ..than switch to another HD input on the tv ...usually they have 3 HD channels..but not all work ...cause ar eon different frequencies or something like that ..Just try them all ..be sure you make the right choice in the channels too on the Hd of the tv ..
Aug 28, 2010 | Computers & Internet
There are gray fuzzy lines across the pictures
Sounds like it could be cracked glass or a dirty lens. if its a cracked lens take it to a repair shop or buy new. if its a dirty lens whew! you saved some money just clean it off good luck please rate,
Rshutterbug
Aug 17, 2009 | Canon PowerShot A75 Digital Camera
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
FUZZY PICTURE
1 thing you can try. sounds silly but. the older a TV is the 75om cable in the back. un hook it, clean it with a tuch of alohol, and the post it hooks to. dry it good. and put it bake on tight. must times the white line come from a dirty, wore out, or bad cable to the set. best way to test this is wiggle the cable behind the set. if the intenstty of the lines change, it's you cable. replace is. hope this helps.
Mar 20, 2009 | Televison & Video
No screen on the Xbox 360
right do the towel trick it works. wrap the 360 in 2 towels and leave it on for 15 mins. then go bk to your xbox un wrap it. put it near a window if possible ( i did and its working fine) due to it being near a window you will get no overheating and its well ventilated.
Dec 14, 2008 | Microsoft Xbox 360 Console
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
