It starts fine , fills , and washes. After that it gets stuck in cycle. I just replaced motor control board. I notice that after final spin( it gets there with my help) right before the buzzer it will get stuck in that with help will get out of that .
    Genius:
  • 1,075 Answers
Simply tighten the main belt.ie the belt is loose and is slipping and cant turn the drum.adrian.
Posted on Mar 16, 2011
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Oct 17, 2012 | Whirlpool WFC7500VW Washer
Kenmore 417 FLW stuck in final spin cycle
It appears as though this is a known problem with the spin control board component, so ordering a new board should solve the problem.
Oct 17, 2009 | Kenmore 44042 Front Load Washer
E59 Error on Frigidaire front loader - won't spin
I finally solved this same problem on mine error code E59 and the main symptom of the drum never spinning even right at the beginning of the load cycle. I did Test 12 based on the following link: (MAKE SURE THE POWER CORD IS UNPLUGGED TO THE MACHINE)http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf. I found that the motor was fine which meant the problem was with the speed control board. On my speed control board there are 3 locations that connectors plug into it. Make sure these are all firmly connected. One of the three is a very weak press fit connection clamping over the edge of the circuit board. This had wiggled loose on my machine from all the dancing across the concrete floor in the basement this machine does. I pressed this connection in firmly, put everything back together and it started working like new!
Good luck.
Jon
Sep 25, 2009 | Washing Machines
Cycle starts, continual humming, no wash, no movement, just humming noises. Have to stop the wash.
If it hums from start, and it is filling fine from inlet valve, then the problem is usually timer control board or motor control unit board/motor failure.
If it gets stuck on filling forever, check also the pressure switch.
Parts must be tested before replacement.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Zanussi ZWF12070 Front Load Washer
Washing machine tripping elec's
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Sorry.
Feb 27, 2009 | Creda W120VW Front Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Washer agitates for a time then sputters. Does not spin
In sounds to me like you have a motor issue. We have found that on these particuliar models, that the motor tries to run in both speeds at the same time. If you already replaced the control board, then you will have to get a new motor kit. This kit includes directions as well as a new wiring harness and start capacitor. You would have to remove the old motor and rewire the wiring harness (instructions included with the kit) and add the new start capacitor (instructions also included). Job is'nt really that hard to do. Front cover would be all you would need to remove to get to all the parts. Good luck and let me know how it turns out or if you need any additional help. Jim
Sep 05, 2007 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
