Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
My wireless link led is off. the ethernet outputs are working
    Problem Solver:
  • 7 Answers
1.open the router
2. get a tester
3. remove the led bulb that is not working (because to led sometimes breaks because of to much blinking
4. test it if it work
5. or if busted replace it
6. the important thing is its working
7.if you cant open it try bringing it in a computer shop
Posted on Mar 16, 2011
Why is my tv sound not working after lightning storm?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 24, 2014 | Vizio M401i-A3 40" 1080p LED-LCD TV - 16:9...
The router is not connecting to the internet. The internet works perfectly fine but when I plug the ethernet cord into the router it wont work.
Check your computer setup. The ethernet port has to activated on your computer for it to get the router output. This is usually accomplished by going into your BIOS setup and turning it on, that is if you installed the driver during the initial setup of the computer.
Jan 05, 2011 | D-Link DIR-615 Wireless Router
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Aug 31, 2010 | D-Link DSL-G604T Wireless Router
Can noy ged moden check shows working t wireless to work ethernet works an- looking for button to turn wireless on . Lookig for actual button to turn wireless on. Do not know where it is at - Thank You
The location of the Wireless ON/OFF switch is on the right hand edge side of the Notebook. Please see image below, it is No. 8
moz-screenshot-2.pngPlease let me know if the information provided has been helpful.
11997_ov.gif 1. Easy Access Buttons (5) 2. Stereo Speakers 3. Touch Pad On/Off Button LED 4. Fixed Optical Drive 5. Touch Pad 6. Primary Battery 7. Wireless LED 8. Wireless On/Off Button 9. Battery Charging LED 10. Hard Drive Activity LED 11. System Power LED 12. Mute Lock LED 13. Volume Controls 14. Headphone 15. Audio In 16. 1394 Port 17. PC Card Slots (1) 18. RJ-11 (Modem) 19. Air Vent 20. Kensington Lock 21. Power Button LED 22. Caps Lock LED 23. Num Lock LED 24. Keypad LED
Aug 20, 2010 | HP Compaq nx9030 Notebook
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Nov 18, 2009 | D-Link DIR-615 Wireless Router
Usb ethernet adaptor doesn't work
Good day sir, I suggest you check your Lan cable cat 5, to see if its broken, the led mean link, since it is not lit up, the line I assume is broken. Im interested on your first ethernet hardware problem, why is it, that it does not work?
I may help, I'm assuming you are using a laptop, you should get a PCMCIA lan card, which much more compatibility.
Nov 16, 2009 | Computers & Internet
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
or
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Nov 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
49 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
