Question about Tool Box Grill Charcoal
Purchased a toolbox grill and it came with alot of small screws and 1" hard plastic tube like things (4) have no instructions or assembly sheets to let you know what to do with this or these things..... need help please
  • Dan Webster
    Dan Webster Mar 16, 2011
    model number and your location in the world
    Brigadier General:
  • 4,736 Answers
KEG Products is the manufacturer of your grill. You will need to contact them for the Owners Manual.
800-232-5347.
Hope this helps to get you up and grilling.
Posted on Mar 16, 2011
Can you help with instructions on how to install a mesh grill and spoiler on a 2003 X Type Jaguar..... Thank You
i have fitted an "admesh" brand mesh grille and spoiler on my fathers 2004 X type.
the mesh in the spoiler would have just fitted over the existing plastic grille using the supplied clips, if the original grille had not been damaged. i just removed unscrewed the original grille and fitted the mesh one using the same fittings.
for the main grille, i removed the grill from the car (4 screws) and cut out the centre plastic vanes before fitting the new mesh one to it using the supplied clips. i then screwed the whole unit back in place. it took about 1 1/2 hours from start to finish for both mesh grills.
the instructions were quite clear and most helpful.
i do not know which kit you have so do not know specific fitting instructions, but as far as i am aware, most kits would fit in a simillar way and should not be to difficult to fit with a little care.
Feb 25, 2011 | 2003 Jaguar X-Type
Blower not blowing hard
The location for the relay is in under the cowl cover grille. The first thing is to remove the negative wire from the negative side of battery. Then remove both windshield wiper arms (by using a small screw driver and prying up on the plastic cap); mark the location for the wiper arm and remove the nut from the center of arm. Then remove screws holding the cowl cover grille in place and the relay is located just under the grille. Using a small screwdriver pry loose connector from relay. Note there is two types of relays for this car, a non a/c and a a/c relay. Do not get them mixed up when getting new part. Assembly is the reverse of removal. Hope this will help you.
May 30, 2010 | 2005 Dodge Neon
Whirlpool model #GD25DIXH02. The front water dispenser tube cracked at the retaining screw. How do I change the filler tube kit?
Remove the top free door hinge cover and disconnect the plug there . This removes all power to the door . Remove the grill inside the dispensor , and remove the 2 screws at the bottom , holding the dispensor cover on . Lift the cover to remove , and disconnect the receptical , freeing the front . Next , remove the 4 screws holding the white dispensor switch mount , and slide out . Remove the screw holding the water fitting assembly .
Remove the bottom refrig kick plate . Follow the tube about 6 " to a connector , and disconnect the connector . The plastic compression nut , slips off the tubing after disconnecting .
Pull the dispensor tube , up thru the door from the top . Using the new tube with spout , pt number 4388152 . Insert the new tube into the hole from the top , and feed down , thru the door . Re-assemble in reverse .
Oct 26, 2009 | Refrigerators
I neede to remove the headlights for my 2008 E 350 and need instructions. OIt appears that removing the front bumper is needed ? Thanks
Here's some instructions for removing bumper and headlights.
E-Class W211 front bumper removal (standard body style).
Tools needed:
- Automotive wheel ramps (Rhino ramps from Autozone).
- 1/4" drive socket set with 8mm and 10mm sockets.
- #20 torx bit.
- Floor jack, optional but useful.
- Flat blade screwdriver.
Instructions for bumper removal:
1) Turn front wheels full right to remove push-pin fastener at lower front corner of left wheel well plastic splash guard. It's difficult to remove this fastener once the car is up on the wheel ramps.
2) Turn front wheels full left to remove push-pin fastener at lower front corner of right wheel well plastic splash guard.
3) Drive car up on wheel ramps. Block rear tires. Open hood.
4) Remove lower mesh plastic grille. There are five attachment points on the top edge of the grille. You can get to three of them with your hand by reaching between the radiator and the back side of the grille. The two outer ones can be released with a screwdriver also reaching in between the grille and radiator. Once the plastic tabs are released, you can remove the grille by pulling it out from the front of the car.
5) Remove the plastic panel located immediately behind the bumper from the bottom of the engine compartment. This panel is held in place with nine sheet metal screws with a 8mm hex head. Five screws are on the bottom of the car and there are two screws in each wheel well at the inner lower edge. After removing all nine screws you can work the panel free.
6) Disconnect the cable from each fog light and remove both fog lights. They are held in place by two sheet metal screws with a #20 torx head.
7) Remove the side marker bulbs. The one on the passenger side turns clockwise to remove and the one on the driver side turns counter-clockwise.
8) Remove the temperature sensor from its socket on the driver side.
9) If you have a floor jack, raise the car at the jack point on the cross member below the engine. You do not want to raise it off the wheel ramps. But it helps to have more clearance above the tires to work in the front wheel wells.
10) Remove three of the plastic nuts holding the forward half of the plastic wheel well liner in place. It's not necessary to remove the plastic liner. You just need to loosen it up so that you can pull it away from the fender to gain access to the screw and bracket securing the bumper to the fender.
11) Pull back the wheel well liner and remove the sheet metal screw from the rear end of the metal bracket . There is only one sheet metal screw (#20 torx head) holding this bracket in place. Don't attempt to remove the bracket yet. I used a #20 torx bit in a 1/4" socket with a 6-inch extension for a 1/4" drive wrench. The head of the screw faces the ground.
12) Remove the 5mm bolts (8mm hex head) holding the bumper to the headlight assembly between the small lens and large lens (both sides).
13) Remove the two 6mm bolts (10mm hex head) on either side of the large grille area opening.
14) Remove the two 6mm bolts (10mm hex head) securing the bumper to the bottom edge of the crashbar. You can access these bolts through the front where you removed the plastic mesh grille.
15) Remove the three 5mm bolts (8mm hex head) holding each headlight assembly in place. Two longer bolts are on top. One at the rear outer corner and one at the front inner corner. The third bolt is accessed from the bottom. It's in the area above the fog lamps. You don't need to disconnect the headlight cables and remove the assembly. But it helps to allow the headlight assembly to "float" freely while you disengage the bumper from the fender.
16) At this point all of the fasteners holding the bumper in place have been removed. The only thing left to do is to remove the two brackets "clamping" the bumper cover to the lower front edge of the front fenders. Before you do this, position some cardboard boxes, bags of packing material, six packs of paper towels, or other suitable items to protect the bumper in case it falls off the car.
17) The bracket holding the bumper cover to the fender has a "pin" that slips into a slot at the front edge of the bumper cover. There is a matching slot near the front edge of the fender. It's not possible to see this pin from the bottom of the car. Use a flat blade screwdriver to pry the bracket away from the bumper/fender and towards the center of the car. The bracket will "hinge" on the pin at the front end of the bracket. After you swing the bracket away from the bumper, you need to slide it forward to remove it from the slot in the bumper cover and fender. You will probably scratch some paint off of this bracket with the screwdriver. I recommend repainting the scratched areas of the bracket before reinstalling it.
18) After removing the bracket from each side of the car you need to deal with the small plastic "hook" holding the bumper cover to the very front tip of the fender. This hook is an integral part of the bumper cover. Disengaging this hook from the fender is probably the most difficult step of removing the bumper. Simultaneously raise the head light assembly slightly, push the leading edge of the fender outward slightly, and push the bumper cover inward toward the headlight assembly. Don't get too aggressive with the fender. It's aluminum and you will make a real mess if you apply too much pressure on the fender. It took me about 20 minutes to free each side from this hook. It should take you less time, since you now know that the hook exists!
19) Gently pull the bumper forward and away from the car. This is one step where a second person would be helpful. But I did manage to do this step alone. There is a "pulley" like attachment point on each side just below the fender/bumper seam.
To re-install the bumper, reverse the order of the steps above. When re-installing the bracket between the bumper cover and fender, I smeared a thin coating of car wash soap on the bracket to facilitate snapping the bracket back into place.
Oct 09, 2009 | Mercedes-Benz E350 Cars & Trucks
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
The water dispenser bar on my side by side KitchenAid refrigerator (model #KSRB25FHSS02) has a small plastic tube that allows the water to flow out into your cup. That little plastic tube broke in 1/2 and...
Hi Cranberry,
The part your looking for is #8201537. You can see it here.
Threading it through the door is simple if you know the secret to it. First you need to go to hardware store and get something like this about an inch, inch and a quarter. Take a piece of 1/4" tubing with you to make sure the "all-thread" will screw into the tubing snugly.
Now, screw the all-thread into the spout end of the existing tubing (the one in your fridge right now) about half the length of the all-thread. Then take the tail end of the new tubing and thread it onto the left over stub of all-thread.
Open both doors and remove the bottom grill (it's snapped in place) then close the doors. Below the freezer door hinge, you'll see the tubing coupling. Disconnect it and remove the ferrule for use on your new tubing later. Now at the same time, begin pushing the tubing from the top and pulling it from the bottom.
SG
Mar 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
88 Honda Accord left front turn signal assembly
*The Turn signal on the Side of the car next to the headlight*
1. Open the retractable headlights.
2. Remove the plastic shroud around the headlight: two screws in front and one on each side.
3. Look to the outside of the headlight and you will see a single screw in a small plastic cover on the front inside edge of the signal light assembly. The headlight prevents you from getting at the screw straight-on. I broke it loose with an offset phillips screwdriver, and then backed it out with a regular phillips.
4. Remove the plastic cover, and you will see two screws. Remove them.
5. Now you can pull the turn signal assembly forward and out.
6. To remove the bulb holders from the assembly, twist counterclockwise and pull out.
7. Pull straight outward to remove the bulbs. To assemble, follow the steps in reverse. Note that there are two plastic rods on the back end of the turn signal assembly that you will insert into two holes in the channel of the fender
*The turn signal in the bumper*
1. You will need a phillips head And Flat head screw driver, right below the turn signal there is a panel that you can pop out, (or its allready gone, Looks like a Fog light can go in there.)
2. once u find that, (Pretty easy to find) Look directly up in there., there is styrofoam up there and u will also notice a little hole,
3. Stick the Phillips head screw driver in that hole and turn it counter clockwize, The screw will not fall out,
4.once it feels like the screw is loose put the flat head in between the turn signal lense and bumper, the side where you unscrewed it and SLOWLY pry it out,
4. once out, just twist the plug and replace light bulb
to replace just reverse instructions
Jun 29, 2008 | 1988 Honda Accord 4 Door
Tool Box Grill Charcoal Logo
142 people viewed this question
Top Tool Box Grill Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Tool Box Grill Grilling Expert? Answer questions, earn points and help others
