Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water leaking Kenmore 22" Model 9702801 Water is leaking from the bottom of the refrig Seems to be left side halfway back Checked water going into icemaker and looks ok
  • kellim Aug 02, 2008
    Leak found, wasn't refrig
  • Carl Thomas Oct 17, 2008
    I have water leaking from the lower right front of my Kenmore 22 refrigerator. Since it happens every two or three days ( a puddle of about a third of a cup of cold water), I thought it might have something to do with the automatic defrost cycle. Any ideas?
  • Kenmore Master
  • 19,396 Answers
I guess it was water from drain lines, or leak from water lines.
Posted on May 22, 2009
I have a 2008 bottom freezer refrigerator 795.7854 with water on left side of refrig door and water is not flowing. Changed filter and checked water supply and they are ok. What else can I do?
There is usually a solenoid where the supply water hooks up. Need to check it. Pull off hose going from solenoid to freezer and see if water comes out of solenoid when water is pushed on door. If it comes out there, then the line may be frozen.
Mar 01, 2014 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrig leaking from bottom
close the water valve going to the fridge and call for service it may leak from many places is hard to tell blindly.
Jul 25, 2009 | Refrigerators
Water Leak around left front wheel
I would check the defrost drain inside the freezer. this is real easy to do on this model refrig.
  • remove bottom basket (if it isnt frozen in place) and the shelf above it.
  • in th back just below the coil cover in the freezer section there is a ledge that will most likely be frozen over remove this ice using a hair dryer or hot water which ever is conveinant for you
  • you should uncover a drain hole flush this drain with hot water I use a turkey baster or large syringe to forcefully push water thru to clear anything in the drain
  • put it back together and you should be good to go
when ever the unit goes into defrost (which is about twice a day) the water runs over the ledge and then out of the door by the hinge puddling up next to the wheel. this unit has a hard fiberglass drain pan that is built in and unless it has been dropped i cant imagine the drain pan being damaged.
Let me know if you have any other questions Peyton
Mar 07, 2009 | Kenmore 74192 / 74194 Top Freezer...
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Refrigerators Logo
354 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
