Question about Husqvarna Garden
Chainsaw very hard to crank. too much compression,does it have a decompression valve? It's a model 41 husqvarna.
  • Husqvarna Master
  • 2,239 Answers
There is no deco valve on this model, the later model ( 142 ) had a spring assist starter to aid starting, i am quite sure this is retro fittable onto the 41, part no. 530071968.
Posted on Mar 16, 2011
Testimonial: "Thanx, that's all I needed to know.Very good"
Check valve falls out leaks gas 2000 141 EPA PH1
The decompressor valve is a complete assembly and not a serviceable component. These valves are readily available and many reputable Husqvarna shops will carry them in stock.
To replace one, use a long tube socket and unscrew it. Replace in the same manner.
Mar 27, 2014 | Husqvarna Chainsaw Decompression Valve
Need thread size for Husqvarna decompresion valve
dont know off the top of my head however you can get a thread identifier tool for 5 bucks, or if you have a tap and die set you can see which one fits then read the number off the side
Dec 17, 2013 | Husqvarna Chain Saw Models 51, 55
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Husqvarna 345 decompression valve
The345 should have a blue push in deco valve on the r/h side of the cylinder, if not there may be a 13mm blanking screw there, this can be removed and a deco valve fitted.
Dec 24, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Top handle, model # 2040 jonsered. is the same as what model # husqvarna
Husqvarna never used this model in there range, they used the same cylinder,piston and crank assembly in the 41/141 but all other components were different to the Jonsered, the part no. for the Jonsered top handle is 530038327
Aug 28, 2011 | Husqvarna Garden
I have a husqvarna chainsaw 41(1994-05) is what the model number is showing the carb has been rebiult new gasgets it has fire but will not run can u help
The 41 was quite prone to blowing the crank seal on the flywheel side, remove the flywheel and check, at the same time check the flywheel key has not sheared, behind the carb fixing plate is a rubber induction tube, make sure this has not split, als check the impulse seal underneath the induction tube.
May 19, 2011 | Husqvarna Garden
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Huxqvarna chainsaw Model 41
this unit does not have a compression release.you must have another problem some where.let me know what you have either done or not done to the saw and i will be glad to help......
Mar 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
584 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
