Question about Samsung 3LCD Projector 2500 Lumens SPM250W SPM250W
Hello, we have sp2503swx projector the is blinking led lights,on the top of the bottom standby mode and status mode. both blinking. except the led lamps menu.
SOURCE: Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Posted on Nov 28, 2009
Gigatech
  • 259 Answers
SOURCE: Blinking status light
6 cycle (0.5 sec On,
0.5 sec Off) is a lamp error!
0.5 sec Off)
Lamp fails to light. Wait a full
minute and then turn on again.
Even though the lamp is not old there may be a defect in the lamp. I know the lamps are expensive but this may be the problem. If you have a lamp that was removed due to age but still worked you could use the lamp to test it.here is a link to the user manual:
http://www.iusb.edu/~libg/ims/VT570_MAN.pdf
Hope this helps. :}
Posted on Apr 02, 2008
Marrie
  • 563 Answers
SOURCE: Panasonic PT L501U Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Posted on Apr 18, 2008
  • 375 Answers
SOURCE: STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Posted on Jul 30, 2008
SOURCE: Optoma EP719 lamp does not come on
Ok, so forgive me, I'm going by memory. Take the top cover off (4 screws on the side). Take the top silver shield off, look at the screws and only take off the ones you need. It's ok if you take more off, but its just more screws to track. You will need to take off the back outer cover. You will need to unscrew the hexagonal screws that the vga-out port uses to screw the connector to, as these are holding the back plate on. Once you get in, the board you need to look at is on the bottom back. Look for a capacitor that has a rounded top, not flat like the others. You will need to replace this with the same voltage and capacitance. Try an electronics site on the internet to get the right replacement if you cannot find it locally. Sorry for the poor instructions, but its just been too long. As a practice, take pictures as you go (during removal of parts) and you can use them to reinstall. Hope this helps as mine is still working.
Posted on Sep 09, 2008
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Dec 02, 2009 | Optoma HD65 DLP Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Problem with Casio xj-s35 projector
You have to disconnect power to reset it.
Nov 08, 2008 | Casio XJ-S35 DLP Projector
Jul 24, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Samsung 3LCD Projector 2500 Lumens SPM250W SPM250W Logo
101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
