Question about Philips Magnavox MWR10D6 DVD Recorder
Error message E54040990
Error E 54040990 message and can not record disk
  • 4 more comments
  • jeeeeesse Sep 10, 2008
    same problem but error message is E 4 54037380.
    Sometimes on Sony dvd+r but 2 or 3 trys will get it hoing. cannot record on verbatim printable dvd+r and I am stuck with 100.
  • Robin Whitlowe Oct 28, 2008
    .I have the same problem. I am getting the error code E454040990. I have used all types of disc's. If I wait a while it might work. This error code is not in the manual. At first it was happening periodically, but now it is happening all the time.
  • sarwen Nov 15, 2008
    Same here..same error code...no formatting anymore and just error after error...have tried several different disks brands...can no longer record anything..it tries after a reload but the error comes up again later...have tried the +r and the +rw...memorex and phillips...very frustrated..i work at night so i miss my shows...now i really miss them!! Have not had this even a year it was my late Christmas gift early this year!!
  • nrwilson Dec 04, 2008
    I have the same problem. What do they do make products to last 6 months and then they break down. I have'nt been able to record for 2 months now. I cannot afford to fork out 200.00 every 6 months for a new one. If someone knows a solution please let me know. Error 4 54040990
  • docdr Feb 12, 2009
    I have the same problem and yes it is that exact error code number
  • omnivitke Apr 08, 2009
    Error message E 4 54040990 just started when i replaced the one year old DVD/RW and both +\- RW disc bring up same Error Code
Make sure that the discs are right for the unit. As this unit is now absolete you may have trouble finding discs. For one time write, try to find Verbatim Movie Discs 1x-8x. Try Microcenter. Use DVD RW from Maxell 1x-2x. I believe they are still available at walmart.
Posted on Jul 21, 2009
    Problem Solver:
  • 5 Answers
I HAVE LOOKED FOR THIS ERROR MESSEAGE AND ITS NO WHERE IN THE MANUAL ARE YOU SURE,THATS WHAT IT SAYS .IF YOU NEED THE MANUAL WILL BE HAPPY TO SEND,IT HAS SEVERAL ERROR CODES
Posted on Aug 20, 2008
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Unable to record,cannot read disk,is message on screen,
May be dust/dirt on the lens, so try blowing gently or using a DVD cleaner disk.
Oct 07, 2008 | Panasonic DMR-ES10 DVD Recorder
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
May 28, 2008 | Centon Electronics MP4-001 MP3 Player
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Philips Magnavox MWR10D6 DVD Recorder Logo
610 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
