For Atheros AR8121/AR8113/AR8114 PCIE Ethernet Controller v1.0.0.9 2008/04/25) Check Cable connection! PXE-MOF: Exiting Intel PXE ROM. No bootable device -- insert bot disk and press any key
    Master:
  • 346 Answers
Hfc_32 - Hi, your system is telling you that it can't find a boot device (Your hard drive) and is trying to boot from a network instead (PXE) which doesn't exist.
Either something is wrong with your hard disk or somehow the boot device got changed in your system's BIOS.
You didn't say anything about your computer (laptop, desktop. Mac or PC?). There are a few things you should try (if you're comfortable doing it).
The easiest thing to try is to get the CD/DVD of your operating system and place it in the optical drive (with the error you described on the screen) power it down and then in turn it back on. It should boot from the OS disc and let you know if it finds your hard disk. You didn't specify your OS so we can't go any further there. Hopefully it will find your hard drive. Then you'll know that it didn't die.
If the disc doesn't see the hard drive and your PC is a desktop system (don't do any of this with a laptop) open the case and make sure the power and data cables are securely connected. Try booting again. The hard drive will be in a cage type holder usually at the front of the system.
Lastly, if the system still doesn't boot look in your system manual and find out how to get into the system BIOS. Follow the instructions and go to the Boot section and see if you hard disk is listed and if so make sure it is listed as the FIRST boot device.
To try to get into the BIOS if you don't have the manual try hitting (on separate boot attempts) at the beginning of the boot process (when you first see the white text on black boot screen just after you've applied power) first the key, then if that doesn't work, next try the key, then the key and finally try hitting the key.
Good Luck and Thank You for using 'Fix Ya'
Mikeywaf
Posted on Mar 16, 2011
  • Michael Wafkowski
    Michael Wafkowski Mar 16, 2011
    Sorry the system didn't take my function keys in < > brackets.
    The above should read DEL key, F1 key, F2 key and finally ESC key.
    Sorry about that
    Mikeywaf
No bootable device packard bell-what do i do?
check your bios settings and make sure your hard drive is first in the boot order.
Nov 24, 2012 | Computers & Internet
Why won't my laptop load windows 7 when turned on? All I get is a black screen with acer on it.
Need to have the hard disk checked. The computer is not finding the operating software to run. This is found on the hard drive. Hard drive is bad.
Nov 10, 2017 | Acer Computers & Internet
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
Every time I turn on my computer the following message appears: "For PCIE Atheros Ethernet controller v1.0.0.5 Check cable connection ..! pxe-e63: error while initializing the NIC pxe-mof:...
It sounds like the hard disk is faulty, the machine is trying to boot via the network card as it cannot find a bootable disk. You could try removing the hard drive and reseating it but the disk could be dead.
Apr 04, 2011 | Acer Aspire One PC Notebook
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
Press F2 and enter setup as it looks like your device is set to boot from the network instead of your C drive. You can change the boot order in the setup.
Oct 03, 2017 | Acer Aspire One D250 Netbook
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
Jul 02, 2017 | Acer Aspire One PC Notebook
When booting up gives a message states "For Atheros AR8121/AR8113 PCIE Ethernet Controller v1.0.0.4, Client MAC Addr: 00 A0 D1 A6 50 99, Check cable connection!, PXE-M0F: Exiting INtel PXE ROM. Operating...
The message you are seeing is your system trying to boot off of a network source. The boot device order has either been changed in your BIOS or the system is not seeing the hard drive with your operating system on it and is not able to boot from it.
Robert from Blitware
Jun 22, 2010 | Acer Aspire 6920 Notebook PC
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Computers & Internet Logo
514 people viewed this question
David Payne
David Payne
