Question about Vacuums
I have no manual. I have ingrediants in pan but NOW don't know how to set it...timer etc
  • 1 more comment
  • Ruth Ann Tomanek Mar 16, 2011
    No! Not a vacuum. It is a Zojirushi Bread Machine. Model# BBCC-15
    I have a Zojirutshi Bread Machine NOT a vacuum. Model # BBCC-15
    BBCC-N15 is the number on the back of my bread machine
    President:
  • 1,961 Answers
I need to know the brand and model number so I could locate the right user manual for your unit.
Please post back.
Posted on Mar 16, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 16, 2011
    Hello!
    There is a variety of model that comes with your breadmaker machine that has the BBCC and specify the 15 numbers. If your model do not have the prefix letter like BBCC-S15, N15, M15 and Q15, then my suggestion is to look for the closest manual for your model from the list of BBCC on the link I provided below
    http://www.zojirushi.com/support/manuals...
    Try viewing the user manual by selecting the model. You must have adobe acrobat reader installed in your system to view this file because its pdf file.
  • Danilo Baraquiel
    BBCC-M15 user manual is also the manual for the BBCC-N15
    here it is
    bbcc_m15 / bbcc_n15.pdf
    the recipe book for the bbcc n15 also same with bbcc m15
    here it is
    bbcc_m15_rb / bbcc_n15_rb.pdf
I bought a townhouse with an Electrolux 1561 built in vacuum cleaner. The previous owner didn't leave any instruction manual. It also doesn't seem to be wired correctly as it has to be plugged in...
I don't have an instruction manual, but if the vacuum is running continuously when plugged in you may have a bad relay.
http://www.beamvac.com/usa/support/trouble_shooting.aspx
http://www.centralvacuumstores.com/cvs/trouble_help.php
Aug 03, 2011 | Electrolux Centralux Vacuum
I don't know how to operate the radio, how to set time, alarm, etc. Is there a user manual available for this model?
what model, this is listed under vacuums , please repost and add the make and model number
Jul 15, 2011 | Vacuums
How to cook hamburgers - temperature, etc.
Prepare Patties
1. Put minced scallions and chopped mushrooms in bowl.
2. Add red wine vinegar.
3. Add ground beef to bowl.
4. Mix everything together with your hands.
5. Flatten the beef into four patties that are 1/2-inch thick and 5 inches in diameter.
Cook Patties
1. Set stove-top grill or burner to medium-high.
2. Preheat nonstick frying pan. The pan is the correct temperature when a drop of water dances on its surface rather than sticking to it.
3. Place patties in the pan and cook for 2 to 3 minutes.
4. Flip patties and cook for another minute, and then add sliced cheese to the tops of patties if desired.
5. Cover pan and allow burgers to cook for a final 2 minutes. Cook 3 to 4 minutes for well-done burgers.
6. Remove hamburgers from pan and place in hamburger buns.
7. Add condiments and toppings such as ketchup, mustard, sliced tomatoes, lettuce, red onions and pickles.
Share some please! ü
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 12, 2011 | Vacuums
Atlantic azurea 100T - extractor fan - how do I adjust how long it stays on, I have one that the previous owners of my home put in and it stays on all the time. Please let me know! Thanks, Laura
Hi Laura,
There are many auto timer enabled extractor fan's available in the market but it could cost you more, therefore I would recommend an alternate solution for you.
All you need to do is replace your fan's switch with an auto timer.
For e.g. An auto timer which will switch off your fan after the desired time automatically.
Examples of an auto timers can be found on these links :- http://bit.ly/kUNC4x
http://bit.ly/kJPprC
So when the timer goes off , the fan stops by itself , and you don't have to worry about it any more.
Or you can get a new extractor fan with timer as well , check out an example in this link :- http://amzn.to/jybLfl
If you want to know how to install a bathroom timer switch , please follow this link :- http://bit.ly/lN7p67
Hope this helps ..:) Your feed back would be appreciated , let me know in case you have any queries.
Jun 02, 2011 | Vacuums
I replaced a Intermatic light timer with a GE 15086 timer. I have read several solution, but none fit my wire sceme. This is hooked up as a 3-way switch so the second switch can turn outside lights on...
1) GE 15086 is not a 3-way timer.
GE programmable timers are for single-pole switch replacement only. I have tested this timer, and own several GE timers, and many other brands.
2) Open following link to identify timers that work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
3) After buying correct timer, then you need to review wiring diagrams carefully because the timer replaces 1 of the 3-way switches, but other 3-way switch has to be wired exactly right to match your brand of timer.
4) Links on page above show manuals for each of the 3-way timers. Compare wiring for each timer with Intermatic wiring that you are replacing, because Intermatic is wired differently than Aube.
5) Or just buy another Intermatic ST01C or EJ500 or EI400, etc, and wiring with change out 1 for 1.
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Vacuums
GE 7 day timer 15091 set day and time and set programs correctly. Timer works right for several days then timer resets itself and loses time and programs. This is the third GE timer that I have...
1) If you have chronic problems with electronic timers, then circuit is suspect. Buy cheap circuit analyzer and plug into same outlet. Try timer on different outlet on different circuit breaker. Change Load (lamp, fan) to see if same problem occurs with different load.
2) Maximum load for GE 15091 is 600 watts incandescent. There is no HP rating, so timer probably not made for motor loads since motors draw high initial amperage. For heavier duty timer, with 1250W incandescent and 1/3 HP, select Woods 59201.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
3) I have tested GE timers. They are made well.
The 15091 is sold under different brand names, so it is successful design that's been around a while.
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 30, 2011 | Vacuums
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
I lost the instruction manual and I don't remeber how to set my timer the model is EMT757-UL
EMT757 looks very similar to Westinghouse 28449
Manual for Westinghouse 28449
http://waterheatertimer.org/pdf/28449_59_TimerManual.pdf
If this is correct timer and manual, add comment saying yes or no.
Aug 31, 2010 | Vacuums
RE: Installing rainbow E series water pan latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=652000
Posted by bettyannsoto on Jun 06, 2008
Need to know how to install rainbow water pan latch and spring latch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow latch can be replaced but I believe it is a pop rivet that holds and replaces the old latch and to replace the new latch, I have seen it done but if you don’t have the right tools you may want to contact your local vacuum cleaner dealer in your area, it can be done. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
