Question about Car Audio & Video
I need to know if i can hook up a amp and 15" speaker to my stock radio,also do i NEED speaker wire
  • 242 Answers
You can do this, you just need a line out converter. Like shown here. This would connect to your rear speaker lines and allow you to lower the level to that which would go into the amplifier. In a regular sedan type car you wouldn't need very much speaker wire but you'll also need an RCA cable to connect the line out converter to the amplifier.
You can also look for an amplifier that has a high level input and do the same thing.
Hope this helps.
Ray
Posted on Mar 16, 2011
Speaker wire
Sorry to hear that. you may have blown out the internal amp channels in the stock radio.
Jun 02, 2013 | Buick Cars & Trucks
I have an 04 Nissan Altima I want to keep the stock radio but want to hook up an amp to it. There are no RCA hook up on the back of the radio. Please help, how can I do this?
You need a high/low converter. The converter will connect to two speaker wires and, covert that high signal to a low signal to run the amp. The converter will have RCA outputs for the amp. You will also need an amp turn on wire. The accessory wire (switched 12 volts) from the radio will serve this purpose.
Since you are already behind the radio; the accessory wire you need is purple in color. Left front speaker (+) is blue/white,(-) is blue/red. Right front speaker (+) is white/black, (-) is blue/black. You can use the signal from these two wires for the amp.
Sep 15, 2012 | Cars & Trucks
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
I have a 93 chevy and i want a subwoofer put in it.. is there a way to hook it to the stock radio and if their is where
you can buy a radio wiring harness at a discount store or an aut parts store, it comes with directions. Hope this helps Tim
Aug 25, 2010 | 1993 Chevrolet K1500
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 02, 2009 | 2003 Mercury Sable
Installing radio in 85 mercedes-benz
there is no amplifier. you just need to find the memory wire that is hot all the time and the 2 wires that are hot with the key on. One is for radio operation and the other is for antenna operation. The speaker power is supplied through the fader switch in the center console and the switch is powered by the head unit. Just hook up your circuit 30 and your 2 circuit 15 with a ground and run you speaker wires to the head unit or if you are installing an amp from the wires from the fader switch. That switch can be popped out with a flat blade screw driver, Hopefully i have been helpful
May 28, 2009 | 1985 Mercedes-Benz 190
Puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 16, 2009 | 2002 Chevrolet S-10
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
