Question about Frigidaire GLTF1670A Front Load Washer
Takes 3 hours to wash a load of clothes
The wash cycle is now taking up to 3-4 hours per load to complete. Nothing has been changed lately.
  • dlynnp50 Aug 09, 2008
    My machine does not advance automatically thru the cycle, needs to be manually advanced. The selector knob almost seems stripped but has been this way since new. Machine is three years old. Any similar problems or solutions?
Make sure you are using soap the is for front loading machines. (he)
Posted on Aug 01, 2008
Why does it take 2 hours to wash a load of clothes when timer show 53 minutes to wash it? It has taken me 6 hours to wash 3 loads of clothes. They are regular size loads not extra large loads.
Leiloni, is this a new machine with built in sensors that detects when clothes are clean, when soap suds are still present and all that fancy stuff, or is a plain Jayne washer with a bad timer.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 07, 2016 | Washing Machines
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
1 1/2 PER LOAD
This is joyce
It is according to what cycle you have it set on and what kind of detergent you are using. if you use something other than HE detergent you may have a very long cycle, its trying to get all the suds out of your clothes, and yes the cycles do range that high.
Feb 11, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Clothes washer
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Feb 20, 2008 | Kenmore 24032\24036 Top Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
