Question about Hoover Vacuums
I have a Hoover WindTunnel Model # U6445-900. The on/off switch needs to be replaced and I'm not sure what parts are needed to repair it. Thanks Gloria
  • 694 Answers
You can order any parts needed at the below link. This is a parts diagram. The switch kit doesn't have a part number here, but it's the second item on the list.
http://www.fiorijanitorial.com/p-447-hoover-windtunnel-parts-self-propelled-body-u6423-900-u6425-900-u6425-920-u6431-900-u6445-900.aspx
I recommend using the below site to order. It provides a clear picture of the switch kit.
http://www.sweeper-city.com/howiswkit.html
Posted on Mar 16, 2011
Service manual hoover windtunnel u 6485-900
http://www.vacshopusa.com/windtunnel.htm
it is cost $4.99
Dec 06, 2012 | Hoover U6485900 Bagged Upright Vacuum
Hoover Wind Tunnel Off-0n Switch
not sure about the part number.
but you can get it off by removing the four screws and the pulling it from opposite side
Jul 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel bagless vaccum model uh6000 on/off switch no longer working, must plug/unplug unit to use. Can switch be replaced?
Yes they can be replaced and are relatively easy to fit. In my opinion, Hoover are one of the best vacuum manufacturers when it comes to obtaining spares and you should have no problem getting one. I did a (very quick) search and this switch apparently fits all Windtunnel Hoovers:
If this doesn't look like your switch, I suggest calling the supplier to verify which part you need for your model. If you'd rather get one fitted for you, any competent appliance enginner or an authorised Hoover service centre should be able to obtain and fit the part easily. I wouldn't pay more than $20-25 in total as they take about 5-10 minutes to fit, max.
Nov 04, 2010 | Hoover Vacuums
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
Hoover self propelled bagged windtunnel upright model #U6435-900...how do you remove the green plastic shell cover to get to the part that secures the v belt...we need to secure the bolt and cannot get the...
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change;
Thank you very much,
Chris Jones
GoVacuum.com
Jan 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
The on off swtich doesn't work on our hoover windtunnel vaccum cleaner. Can it be repaired?
If its just the switch then by all means it can be repaired or replaced. If it needs replacement and the part is not available, you could replace it with a generic switch which may need some modification. Alternatively you can bypass the switch with the wiring and turn the machine on and off at the wall outlet.
Best wishes,
Graemevm
Jun 06, 2009 | Hoover Windtunnel Supreme U5280-900...
I have a hoover windtunnel v2 the brushes underneath wont turn ? its suppose to be beltless what do i do to fix this
Are you sure it is beltless? What model do you have? Looking at another manual there may be a seperate on off switch for the brushes but would need to know your model to be sure.
Dec 30, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6434-900 WindTunnel Bagged Supreme
R U SURE THAT IT IS NOT JUST A SAFETY CUT OUT SWITCH , SOME MODELS HAVE A BLACK BUTTON BEHIND THE BRUSH HEAD DIFFICULT TO SEE SOMETIMES
Aug 17, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
243 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
