Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
My physical formatting of my 1tb external hard drive was interrupted. will it damage the internal programs and affect the good working condition of my external hard drive? i'll wait for your reply. thanks in advance
  • 54 Answers
The power interruption might have damaged the partition you were working on at the time. Try reformatting it and this should solve your problem.
Posted on Mar 16, 2011
    Sergeant:
  • 154 Answers
It'd help if you could say what kind of interruption you experienced. As long as its working now, I\d suggest you copy all your data onto another storage device and do another format. It'll take care of any bad or corrupted cluster that might've formed. Your data should be fine.
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
How can I recover my files after I drop my external hard drive?
First of all - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 22, 2012 | Western Digital My Book Essential 1TB...
I have an external hard drive that I want to use as a PVR , my satellate Tv provider says that it can not be any more than 1TB. the drive I have is 1.5TB, can I partition the drive and make it look like it...
there are several programs suited for this task, just google search for a partitioning program and follow the wizard steps in the program to re-format a partition to the appropriate size and format.
Jul 27, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
HI... Can I clone my internal drive (which is just about full) to my Iomega 1TB external drive...? Thanks
http://www.runtime.org/driveimage-xml.htm this program will allow you to clone your hard drive directly to your external, you can then expand the partition using 'disk management' which can be found typing it into the 'run' window from the start menu. this will erase the external drive however and i wouldnt recommend booting from it externally.
Feb 25, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
New 1TB My Book Essentials ext drive not recognized by laptop
There are times when external drives need to be inialized and formatted before they can be recognized by a computer. There are other times when the drive letter that the external is looking for is already being used and it does not show up.
You can use the disk management utility to initialize, format or change drive letters around. You do not want to change your C drive, also usually called drive 0. Below are directions for accessing and utilizing this tool:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
This should get you to see your external. If you don
Jan 16, 2011 | Western Digital My Book Essential 1TB...
Need to know dc voltage for simpletech external hard drive 1tb
12 volts Dc and 1.5 ampere with External terminal as Negative Polarity and internal as Positive Polarity.
Good luck
Thanks for using FixYa.
Jul 06, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
Feb 15, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Hard drive unaccessible
There is a program called On track recovery.
This application successfully recovers data from damaged hard disks.
You will need and extra storage where to transfer the recovered data.
Don;t forget to rate this answer if it helps.
Dec 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Partial format of WD 1TB external hard drive
Look on the Internet for a "file scavenger" program.
Compare it to reconstructing the table-of-contents of a book,
by reading each page & chapter of the last 93% of the book,
and recording what you found & where you found it.
You'll need another 1TB drive, if you find anything to "recover".
Sep 10, 2009 | Western Digital My Book Essential 1TB...
Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
79 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
