Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
I can't maintain temp below 39, some water is leaking.
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
The coolant light flashes on but the temp gauge does'nt go past the middle when the car is running
YOUR TEMP GAGE WILL NOT REGISTER CORRECTLY WHEN THE COOLANT FALLS BELOW A CERTAIN LEVEL. WHEN IT IS SMOKING IT IS EXTREMELY HOT. IF YOU HAVE A COOLANT LEAK THAT BAD IT SHOULD BE NOTICEABLE EVEN WHEN IT IS NOT HOT. YOU NEED TO FIND THE SOURCE OF THE COOLANT LEAK. WATER PUMP, COOLANT HOSE, FREEZE PLUG, HEAD GASKET, RADIATOR CAP LEAK, OR RADIATOR, OR HEATER CORE. CHECK THE ABOVE AND YOU WILL FIND THE SOURCE OF THE LEAK.
Feb 05, 2012 | Audi A4 Cars & Trucks
The dehumidifier machine is running however, not producing any water in the upper bowl.
The problem you're having with your dehumidifier, may be the result of one or more of the basic, but solvable problems and solutions listed below:
1. The Humidity Extraction Level is set to High. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Remove, inspect the filter and clean if necessary. It it's a
Washable Filter, allow it to thoroughly dry before reinstalling it.
3. Obstructed Air Flow. A minimum of 12" to 18" clear air around the entire unit, must be
maintained.
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in
basement applications. The air temp at floor level is colder than the air temp at shoulder level.
Dehumidifiers don't work well in that temperature range (Unless, it's a Low Temp model). Raise
the unit up off the floor on to a sturdy table, counter top, etc, that can handle the weight of the
unit, plus a full tank of water.
If you troubleshoot the 4 things listed above, it may quickly solve the problem. Please let me know. Thanks.
Jun 18, 2011 | Danby DDR600R Silhouette Dehumidifier
Have overheating problem. can drive vehicle for 50 km on medium to steep hills and flat 50/50 car has maintained even temp on gauge the last 5km suddenly temp rises. no visiable leaks. but all the water in...
It sounds like the cylinder head gasket is leaking internally, forcing coolant into the combustion chamber and getting burnt off through the exhaust. Check the tailpipe for excessive white smoke while the car is running.
Jan 09, 2011 | 1997 Honda CR-V
My 97 buick park avenue is leaking and causing the temp to go up where can i find the leak at?
It could be a number of places. I assume you mean that the coolant is leaking. You need to get it pressure tested to find the leak if it is not "dripping" where you can see it.
Nov 15, 2010 | 1997 Buick Park Avenue
Having problem maintaining water temp after water
This is either an air lock or a leaking headgasket. Remove the rad cap, with the rad full, watch for air bubbles. You didn't tell us if you were adding coolant??
Mar 28, 2010 | 1993 Ford Taurus
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
32 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
