I want to hook up a Blu-Ray to my 1999 Mitsubishi TV, but not sure how or if it will work. I have looked for visual aids for making a connection, but everybody out there thinks everybody on earth has an HDTV. Help!
  • 4 Answers
You might not be able to play BluRay discs if you connect to this TV. A TV of that age will only have analog inputs. The copy protection on BluRay requires a digital, copy protected connection. Having said that, you might be able to play DVD's on a BluRay player that has analog outputs. Depending on your TV, I would say you have composite (yellow RCA connector), S-Video (multi-pin connector), and possibly component (red, blue, green) inputs on this TV. Searching Walmart's web site, I see several inexpensive blu-ray players with composite and component outputs. Grab one of those, and you will be good to go.
Posted on Mar 16, 2011
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
My mitsubishi tv has a phone jack looking plug then a anntena plug part , how do i hook up a dvd player to it
it could be an HDMI port for connecting HDMI cable. If your DVD player has HDMI output then you can connect it.
or it could be a usb port for playing videos from usb devices like pen drives and portable hard disks
i dont think tv has a phone jack
Feb 28, 2016 | Mitsubishi Televison & Video
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
How to hook up my dvd player to the t.v.
Hello
You haven't given any specifications about your tV here. Anyway, you can hook up the DVD player to TV using an AV cable. The AV cable will have three cables together with two RCA connections at each end of each cable. Look at the colour of them. Usually one Red, one White and an other will be yellow. Just connect them to the sockets of both DVD and TV accordingily, and switch ON both devices, select the tV input to AV1 or AV2. If all the connections are correct, you will see the logo of Mitsubishi on TV screen. This is the picture of AV cable. OK.
Nov 08, 2011 | Mitsubishi DD-8030 DVD Player
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
DVP-NS77H will not work
You need to make sure that you change the input on the TV. It is most likely AUX1 or video input 1. Look on you TV remote for a button that says "input" or "source". Make sure your DVD player is on, press press play, then hit the input or souce button on the remote.
Dec 23, 2008 | Sony DVP-NS57P
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
