Question about Pioneer Car Audio & Video
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower volume but the bass distorts at higher volume. I tried it without the amp and the sound quality was just as good but still distorts the bass at higher volumes. Should I power the speakers with the head unit and use the amp for a subwoofer or do I need 2 amps?
    Sniper:
  • 50 Answers
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Posted on Mar 16, 2011
Dodge ram 1500 head unit shorted out
The output IC mounted on the heat sink is the part that will burn
if you did a bad connection using the output wires.
Feb 10, 2014 | Kenwood KAC-9102D Car Audio Amplifier
Trying to install kenwood kfc-1662s speakers in my 07 silverado crew cab and having problems mounting the speakers in. is there a mounting bracket that i need for them?
These speakers are not designed for your truck. I recomend asking chevy of what brands and what size speakers will fit in your truck.
May 15, 2011 | Kenwood Car Audio & Video
How to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Mar 22, 2010 | Kenwood KAC-5204 350 Watt Max Power Stereo...
They are not wanting to play like they should
Hello again debrahood196,
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
May 17, 2009 | Kenwood Car Audio & Video
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Speaker type
I posted a comment on your other post not nodicing this one. But commenting on the choice of amps, It would all depend on what the model number is on the pioneer amp. Also it would depend on what kind of sound you want. Could you get me the model number of that and double check your model numbers for the kenwood sub and amp. The amp that I show when I googled it was rated at 250 watt at 2 ohms no where near 1000. so if I have the wrong amp let me know, I would like to help. Thanks
-Andrew Hawkins
Jun 01, 2008 | Car Audio & Video
Car Audio & Video Logo
138 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
