Question about Cycling
I bought a 2nd hand free spirit 680 nexercise bike and there is alot less tension while pedaling and changing the dial doesn't affect the tension at all anymore. Can it be fixed? and how? Sherry LB Johnson
3 Suggested Answers
  • 34 Answers
SOURCE: cannot get my left hand gear to shift
see mine did that but i used 2 hand and turned really hard if that dont work it could be rusted
Posted on Aug 22, 2009
  • 362 Answers
SOURCE: do you know where to
well if it helps neither murray or huffy ever made free spirit this is a bike company thats been around for a dogs age making discount rate bikes the murray company folded about 15 years ago and huffy has been bought out so that their bikes can be built on a budget with a name once able to draw customers and sears has never really sold any bikes worth holding on to in my opinion and i ride an older bike made by intense cycles from california good luck and if it has plastic spoked wheels you shouldnt have a hard time selling it hope this helps:)
Posted on Nov 18, 2010
Hello the top left hand tension button is not holding tension,It seems as if it has lost a spring.any suggestions Thankyou
Could be there is a mechanical problem.
First, install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning. Set the tension dial at the midway point between the high & low numbers.
Retest. Adjust the tension dials to see if you can achieve the tension you would like.
If the tension dial does not have any affect on the thread tension, then it probably needs service.
Mar 16, 2016 | Sewing Machines
How do i adjust the tension on a ActionC100 exercise bike
I just fixed a C100with the same problem today as follows:
Take off the pedals, seat pole, and side panels ( 3 long screws on the top and 4 short screws on the bottom then push out [from the inside] the pedal shaft outlet covers and gently take the covers off by turning the pedal shaft). You'll see the cable to the wheel and secure it to the lower chassis rail by tape or a cable tie, then undo the lock nut on the cable end and extend the screwed sleeve by 10 mm. You'll then see that pulling and releasing the outer cable will loosen and tighten the magnetic brake more smoothly. Good Luck, Andy
Dec 29, 2012 | Exercise & Fitness
Shimano Clip-on pedal's tension
Check for wear on your cleats and the pedal. Normally, the cleats wear down to the point that they get loose. Rarely does the pedal wear to that point unless damaged or very old.
Jun 26, 2017 | Shimano PD-A530
Bike chain skipping
Bike chains are slightly different determined by amount of cogs on rear sprocket. If you havent changed the chain, adjust the tension of chain.If tension is ok-sprocket would be damaged(teeth worn,slightly rounded)but if same prob on different gear, chain tension/incorrect size chain is problem.
Hope this has been helpful..
Jan 14, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Do you know where to get an owners manual for a Free Spirit BMX bike from 85/86 bought at Sears? Who made that bike, Murray or Huffy? Does having the serial number help me?
Nov 18, 2010 | Cycling
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but...
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Sep 12, 2010 | Mountain Shimano Altus Front Bike...
Pedals move freely
If the pedal is moving too free,but the bike are still moiving forward, it simply mean you are using to low a gear .
Try changing to a high enough gear to satisfy your required tension. Be advised that,
You will also increase your speed,and decrease your hill climbing in the process though.
Jan 30, 2010 | Mountain Pedal Alloy Universal, ...
Engine is noisy with a whirrr
please close my account with you, not what I expected nor do I think you can help me without the $ thing. Some forum this is..
Jun 13, 2009 | 2002 Honda VT 750 DC Shadow Spirit
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Cycling Logo
71 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
