Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Top drawer is blinking code F2 with a wrench beneath. What to do?
  • 77 Answers
F2 means that your rotor is bad and needs to be replaced. You can download the video in the link below to see how to replace the rotor and you can order the part in the link below if you wanted.
Appliance Repair Video
Appliance Parts
Posted on Mar 16, 2011
INSTRUCTION MANUAL FOR PHOENIX BOOKCASE BED
its not hard.. you need the allen wrench. start by removing the planks (unscrew with screwdriver). then the two side drawers (allen wrench to unscrew, then lift/unhook). should result in all three drawer sections separated plus the 4 connector boards. last is headboard - be careful - top piece with the two small drawers separates from it's stand/part of the headboard. if you cant get someone to hold it still while you uncrew w/allen wrench, just take your time unscrewing and breathe lightly :)
Nov 09, 2013 | Coaster Furniture
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is displaying an F2 error code, how do I clear it?
This means the rotor at the base of the drawer is causing some fault. Check the cavity after taking the rotor out and see if there is anything obstructing. Usually a seed or bone fragment. if problem persists you will have to replace the rotor.
see this Youtube video for removing rotor. New rotor is about $90.
Dec 28, 2012 | Fisher and Paykel Dishwashers
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need users manual, (f2) fault
Hi and welcome to FixYA!
F2 means the motor is not being sensed to be rotating. Lift off the wash arm and see if you can spin the blue impeller by hand. If it won't turn, it may be frozen of ajmed by an object like broken glass. Sometimes also if you let the drawer sit unused for a long time (some people only use the top drawer) the rotor will freeze up. The part number is a 525884P if you need a new one, it requires no tools to change it. As for the user guide, you can get one free here:
http://fisherpaykelparts.net/index.php?blockitemid=29
Dec 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top paper drawer will not open or raise paper into place
What kind of copier and model? Some copiers have a button to push or they may have a motorized tray or it just pulls out manually. If you have a mortorized one you may have to clear the error code first? Do you see a small wrench on the display pannel? If so you may have a Minolita copier, if that is the case, touch the wrench and open and close the front door and then press the blinking button on the tray. Mostly, you have the wrong paper in the tray and it lifted up and shifted in the tray and it is now confused. You may need a service tech....
Nov 16, 2008 | Office Equipment & Supplies
Code F2
F2= The motor has not
been sensed rotating
 Foreign object has jammed the rotor
 The rotor has failed
 The hall sensor has failed
 The electronic controller has failed
Please check your email
Jul 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I get parts for a Viking range top. I need two (2) drip trays for the drawer beneath the grill. Thanks...Helen R. Ippel
Hi
Thanks for using FixYa. Youcan order the drip trays for the drawer beneath the grill from the link---
VikingKitchen Range Parts
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Apr 10, 2008 | Viking Kitchen Ranges
Fisher & Paykel Dishwasher
f2 refers to a motor error, you have the manual??? if not hereit is, try taking apart( its mean t for you to be able to service your self, its explained in the manual as to hoe to gfe down ther, the motor/ also called rotor is located within the drawer itself and under the silver screen every compponent twist out to reveal the next look for something under there somewhere preventin the rotor from spinning freely
http://www.fp.co.nz/admin/pdfs/pdf_usecares/527972D_DD_UserGuide_NZw.pdf
Apr 08, 2008 | Dishwashers
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
104 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
