Question about LG 42SL8000 42 in. LED TV
How do I turn off closed caption on 42" LED LG TV
  • 208 Answers
SOURCE: Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Posted on Feb 19, 2008
SOURCE: Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
Posted on May 19, 2008
SOURCE: Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Posted on Jul 29, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Posted on Feb 21, 2009
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
Some channels on direct tv have a black rectangle
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
Oct 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Cannot get rid of captions on TV screen
Have you gone into the menu and located Closed Caption or just caption and turned it off? It might be under the Audio menu or Features.
Feb 01, 2009 | LG 42PX5D 42 in. Plasma HDTV
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42SL8000 42 in. LED TV Logo
153 people viewed this question
Computer Repairing
Computer Repairing
