Question about HP Office Equipment & Supplies
It is not grabbing the paper to print
Hp 3220
  • 446 Answers
It could be from the material you are using, maybe too glossy, or the paper feed roller itself is dirty,yo can clean this first w damped cloth, thats why t is slipping, or the lead edge of your paper is somehow bended, crumpled, pls make sure you check this things.
Posted on Aug 01, 2008
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Printer feed will just not grab paper
Rollers need replacing. They are supposed to have tread like tires, if not, Replace.
Apr 06, 2010 | Canon Office Equipment & Supplies
The rollers won't grab the paper. It may grab toward the end of the print job so that the second half gets printed on the top half of the paper. Or it just won't grab at all.
Dear User,
Your Printer rollers seems to go plane, and they are unable to grab paper properly. You should clean them with a clean piece of paper.
And you can also rub silghtly them with an ambry paper, if needed so that it may grip the paper properly.
Thanks
Jan 23, 2010 | HP Officejet J5780 All-In-One Printer
Paper in lower tray is not being "grabbed" by rollers to start the print or fax job.
I think you need to add some paper to it so that the printer will easily pick them,,,,or arrange the paper onto the tray..
May 17, 2009 | HP 4110 All-in-One USB Printer/Copier/Fax
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Im back .. with same hp printer problem
take a look at the rollers that grabs the paper if its moving or looks like trying to grab paper. swabbing it helps.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Printer does not print
I think trying the solution i gave on this post should solve your problem also http://www.fixya.com/support/t122427-printer_printing_wierd_things_not
Nov 11, 2006 | HP DeskJet 722c InkJet Printer
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
