I have an lg model #wm2010c getting trouble codes for oe & ue drai error and unbalanced i think the oe is causing the other code ive checked all the drain hoses all the way to the pump and the filter is clean. any common issues?
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
arikrom
  • 528 Answers
SOURCE: my LG model # WM2010C is not draining. i had to
door switch need to be replace or bypass :) dont slam the door next time ... :) but it might be the water pump go bad so if the door switch not helping you will need to open the machine and see is the pump got bad
Posted on Jan 02, 2010
  • 572 Answers
SOURCE: lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
Posted on Feb 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: Unbalanced load, sign UE is on, cannot open the door
UE:
• The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum.
See page 17
Posted on Apr 19, 2010
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
Tip
UE Error Code for LG Washing Machines
If you are getting a UE error code from your LG washing machine then you need to know what is causing this code. This UE error code is caused when there is an unbalanced load condition sensed by the washing machine. There are a few things that can cause this and ways to correct it.
If you are doing a load of wash that is too small, this can allow all of the wash to be on one side of the drum. Single heavier items will not work well and will cause this error when spinning. Very light single items may work, but for heavier items you will need to add more to the load to get it to work properly.
If you have a load of heavier items like blankets, and sheets, you may have to stop the machine and spread them around the drum evenly before it will spin properly. Even jeans, shirts, and pillow cases can sometimes all end up on one side of the drum and cause it to become unbalanced. After spreading the items around the drum evenly, try to restart the spin cycle.
If you hear your washing machine slowing down and tumbling a few times when trying to spin, it may be that you machine has a option on it that tries to redistribute the load on its own if it senses an unbalanced load. The machine will try this a couple of times before it will stop and give you an error code.
If you need to reset the code at any time you can do this by unplugging the washing machine and then holding in the start/pause button for 5 seconds. Plug the washer back in and the code should be clear.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Jul 04, 2011 | LG WM-2277HW Front Load Washer
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
Error code ue has displayed on model samsung j845 frontloader
UE " Cause Unbalanced Error . =The load in the drum is unbalanced.
Apr 17, 2010 | Washing Machines
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Dec 03, 2009 | LG WM-2077C Front Load Washer
I'm getting an OE error on my washer--lg tromm 77wd941. I have emptied the lower drai, but I've noticed water in the detergent load area for a couple of weeks too, like it's not draining well.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!
Nov 17, 2009 | LG WM-1832C Front Load Washer
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
