I haave a magic chef furnace model #VR800A 1012 how do you get to the pilot and thermal coupler when there is only a inch or two between the burner and the bottom of the furnace does burner come out as a tray? Pilot went out during the night and will not relight and we're getting a foot of snow!!!! Thanks Jerry
  • susan ross Mar 16, 2011
    does burner tray come out how
  • 17,970 Answers
A thermocouple is used in keeping pilot lights lit in water heaters, boilers, furnaces. Opening gas valves in ovens. A thermocouple has a heavy copper wire leading into the pilot flame, the pilot flame heats the upper 1/3 of the thermocouple lead, generates up to 35 millivolts and energizes a coil to hold the gas valve open; new furnaces do not have thermocouples, they use electronics to sense flame.
Anyone trick there, just need to be patiente, first shut the gas off to the furnace, unthread the thermocouple from the gas valve and from the pilot assembly. Just reinstall it the same way to removed it. Just make sure when you re-light the furnace that the end of the thermocoupler is recieving a direct hit from the pilot flame.
A thermocouple is generic except for it's length. Thermocouples are made in different lengths. Measure the removed part or take the one you remove to any hardware store and replace it with an exact duplicate in length. The parts cost is very nominal.
New thermocouple packages will contain complete do-it-yourself installation instructions and pictures. The package also contains additional clips of various assortments. None may not even be needed.
Not all the parts contained in the package with the thermocouple will be needed. The packages contain an assortment of holding parts and clips that are generic and designed to fit a wide variety of applications.
Install new T-Couple into pilot assembly exactly as the existing one is installed. Element end must be placed exactly the same height as the exiting one. Re-install pilot assembly as found.
Gently thread nut end of T-Couple into gas control valve, starting threads by hand to insure threads will not cross thread and become damaged. Tighten nut snugly but do not overtighten. Just snugly until lightly bottoms out.
Be sure the pilot flame is all blue and no yellow. If any yellow or doubt pilot flame is correct or maybe dusty, clean it out. Blow out pilot flame and allow assembly to cool. Use can of computer keyboard canned air cleaner to blow out the entire assembly.
Re-light pilot and note the result. Test the pilot again note any changes. Also be sure the T-Couple is correctly installed in the pilot assembly. Only the tip of T-Couple or about top 1/3 should be heated. Must be glowing a bright cherry red color.
Hope this helps.
Posted on Mar 16, 2011
  • 643 Answers
The connection to the gas valve is electronic, so proper contact is critical. disconnect and reconnect to finger tight, then EXACTLY one-quarter turn more with the proper wrench, no more, no less, if it wont stay lit, then you might need a new thermocoupler.
I have a magic chef furnace, armstrong series if the pilot light and ignightor both work but the burners wont light is it possible the thermocuppler bad?
The thermocouple keeps the pilot light on. If the flame blows out it shuts off the gas to the pilot lite only the board that has the igniter on it supplies power to open the main burner as long as the igniter is operating. Sounds like the gas valve is nor working.
Nov 19, 2014 | Magic Chef Refrigerators
Where is the thermal coupler located on York furnace model tg8s080b12mp11a
I am not familiar with that unit but, if you follow the gas line in, you will find the control valve where the gas comes out and goes to the burner. The pilot light tube should come out of the same valve. The thermo couple should be there also as it lets the pilot light stay on when it heats up.
Oct 10, 2014 | Tools & Hardware - Others
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
My Magic Chef is a 1979 gas oven and it won't light
OK, you will need to watch the pilot when you turn the temp control. It should get longer and give heat to a coupler that should be attached to your gas valve. If the pilot does not extend when you turn the temp control then the temp control is bad. if it does then your valve is bad.
I hope I got the right kind of machine doing this blind.
Jan 07, 2010 | Ovens
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Wall furnace model # SFB50146B Thermal Coupler. Does it have 2 wires?
if the pilot light stays lit, but the burners don't kick on, it's a problem with the thermostat or thermostat wiring, or a problem with the valve inside the gas actuator
Oct 24, 2008 | Montgomery Ward (223600UP) Heater
Heating & Cooling Logo
395 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
