Question about RCA Audio Players & Recorders
RCA RTD325W via HDMI cable to VIZIO E320VP - How do I get sound from TV to play out of Home Theater unit? More cables required? Buttons to push? Thank You. F.Frost
  • 635 Answers
The TV has a SPDIF ( coaxial ) digital out socket at the back . Get yourself a digital cable and connect it to the RCA Home theater systems coax digital inputRCA RTD325W via HDMI cable - bobhifi_16.jpg
Posted on Mar 16, 2011
Rca dvd surround sound RTD325W is connected by
new cables might help, if you wiggle them and it clears up its the cables or connection terminal on the unit or tV, if the unit call 1800-252 6123, they will give you a return number and address to sedn the main player to no speakers and charge 45.00 TOPS! they will fix it or repalce it for you and ship it back with a 1 year warranty. very cheap and theyre friendly
Oct 07, 2013 | Audio Players & Recorders
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Does not switch to its external speakers
You have a cabling and/or setup issue and need to check your hardware manuals (or find them online) for instructions.
I have a Samsung HT-C550, a DirecTV satellite box, a Vizio 37" HDTV, a Sony 5-disk DVD player and a Vizio Blu-Ray DVD player, all peacefully co-existing (with the use of a bunch of cables as well as a Logitech Harmony 700 universal remote).
The TV (not the home theater) controls the use of the TV speakers.
There are multiple options to get this to work. I run an HDMI cable from the sat box to the TV. (HDMI sends audio & video to the TV). I then run an optical cable from the TV to the CT550 and use the "D-In" setting to get the sound to play.
Instead of the optical cable from TV to CT550, you can run audio from the sat/cable box directly to the CT550 using (red/white) RCA cables from the "audio out" jacks on the sat/cable box to the "AUX1" or "AUX2" inputs on the CT550"
Hope this helps!!
Dec 01, 2012 | Samsung HTC550 Theater System
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
E320VP LED HDTV just purchased. How to I hook up to a home theater system if it has no optical input jack? Thanks.
You should be looking for an optical output on the TV and an input on the home theater. if you mean the home theater has no optical input then you will have to resort to using RCA cables, they wont provide surround sound but most TV channels wont use surround anyway. They are the red and white sockets on the TV. If you need further help please respond with the brand and model of home theater system
Jan 11, 2011 | Vizio Televison & Video
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Samsung ht-z310 home theatre audio problem
All,
I submitted an earlier request trying to determine why surround sound wasn't coming through all speakers when playing my TV.
Looking further into the Samsung site I found out that you MUST connect the optical cable from the home theater unit to the CABLE BOX and not to your TV to get surround sound...I'm currently in the office but will change the connection once home...try connecting to your CABLE BOX instead of your TV and it should resolve the problem.
Oct 02, 2008 | Samsung HT-Z310T Theater System
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
1,003 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
