Question about Yamakawa DVD-238 DVD Player
Samsung DVD-V5600 will not power up. Have tested input votage as OK to main board inside player. Tested time lag fuse - appears to conduct electricity OK.
Does samsung v5600 copy vcr to dvd internally
Does not appear from the owners manual that this unit can do that. Very few units have that ability.
Jul 07, 2016 | Samsung DVD-V5600U DVD Player/VCR
No power denon dvd
There is a capacitor in the power supply that opens, and in some cases it will bulge at the top showing a tell tale sign it is bad.
Apr 11, 2012 | Denon DVD-1930 DVD Player
No pwer, sound or picture
start by checking the power at the mains terminal, then check the continuity of the power input cable. if its healthy then confirm that all fuse in the cable plug is ok.remove the cover and check on the switch mode power supply.conduct a visual inspection to acertain any blown component like the fuse, swollen filter capacitor, the burnt resistors and diodes. if they do not seem to appear phisically burnt then conduct a meeasuring test with a multimeter.
replace any faulty component and test the television by opening the power input fuse and connecting a 100w bulb in series and feed in the power. if the tv oscillates and the bulb lights up then gets dim gradually then the tv is working hence you can now remove the series test bulb and place back the fuse and connect all the cables in place and feed in the power and you see your tv lighting up
Sep 21, 2011 | Vizio L32 32 in. LCD HDTV
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
Jan 22, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Philips DVD Recorder not powering up Model No DVD R3380/05 - 8622 810 12839 made in Hungary Tested Mains Cabel Power is going inside alright, but no display.
there is a small glass fuse inside on the power board , it could be this but take care there is a really high voltage(400v) on that board even when its unplugged it stores the power in the caps.
Nov 28, 2010 | Philips DVDR3380/05 DVD Recorder
Can I record programmes from tv whwn I have samsung dvd v5600
Afraid not! ... You need a Recordable DVD player to record TV programs....
The Samsung v4600 is just a DVD player, with no recording capabilities.
Sep 24, 2009 | Televison & Video
TV has pink screen then white snow intermittently
Try to play with DVD player. Also try to test on another inputs. If the problem persists, the main board may be defective. Another reson could be the T-con board. To find out whether the T-con board or main board cause problem, you need open the TV and check inside.
Aug 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Unit won't power up. Have checked fuse, Good. Now what?
Check out this website for troubleshooting tips and repair of you dvd player. Paste the website into you address bar. http://www.drx9000repair.netfirms.com/ They have a lot of information on repairing these players and they also do repairs.Hope this helps you with your problem.
Apr 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung dvd v5600
Check D1SS16, a diode in secondary supply near the transformer. It's probably short circuit. Replace it with an SF-26, 400V, 2A rectifier diode, or equivalent.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Yamakawa Televison & Video Experts
Electro Med Services...
Are you a Yamakawa Televison and Video Expert? Answer questions, earn points and help others
