Question about Maytag MMV1163DB Microwave Oven
The microwave is blocked and you press the buttons and it wont work and it says -se-
  • Maytag Master
  • 6,771 Answers
The microwave oven is showing a systems error, which means there is a short keypad membrane. The solution is to change the keypad to get it functioning.
Posted on Mar 16, 2011
What does se mean on Samsung over the range microwave model #smh9207st
The SE error code means a key has been depressed for more than 10 seconds. Press the "Clear" button, does it reset and work normally? If not, try completely cycling power to it. If that doesn't work you will probably need to replace the touch pad assembly.
Aug 02, 2016 | Samsung Microwave Ovens
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
Unable to press buttons and message appears --SE--
The word --SE-- means systems error, caused by a short in the keypad membrane. The solution is replace the keypad to resume normal operation.
Mar 20, 2011 | Maytag MMV4205 Microwave Oven
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Maytag MMV1163DB Microwave Oven Logo
323 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
