Question about Toshiba Canvio 500 GB USB 2.0 Basics Portable E05A050BAU2XK (Black) Hard Drive
I plug my hard drive into the computer and u can see the safely remove hardware sign at the bottom right of the computer but it doesn't show up on My computer and when i open other programs while the hard drive is plug in the programs freezes until i unplug my hard drive
  • Toshiba Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 16, 2011
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
or
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
External hard drive stopped working
plz try in another usb slot, if the problem persists then try to format the hdd and check.
Sep 02, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
My external wd elements not reading and the light in the hardisk is on but not blinking
Could have picked up a virus from your friends computer, or the device is just on the fritz. It also could have been corrupted. When removing an external hard drive you should always go to the bottom right click on the little green arrow icon and select "safely remove <your device>" otherwise you risk corrupting the files on it. Plug in the hard drive to your computer. Right click on Computer/My Computer and select Manage. Click on Disk Management on the left side. If your device shows up then the drive most likely has corrupted files or the file table. Right click on your device and initialize it if it isn't and then format the device and it will work again. You will lose all your data in the process. You can download Recurva from piriform.com to try and recover your files if you like. If the device doesn't show at all in disk management then I'd say its toast.
Dec 01, 2012 | Western Digital Computers & Internet
Do I leave sandisk crusier blade in the usb port at all times and jusr turn on when vault pops up
you should always remove the usb hard drive through the safely remove hardware option once plugged in there should be a green tick in the
bottom toolbar in xp in W7 will be the white triangle just click on these and you will see the safely remove hardware option
if you dont use this method you might damage the drive
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope it helps
Jul 16, 2012 | Computers & Internet
1TB Drive works fine; never had an icon associated with it though. What gives? And I assume it doesn't need to be "ejected" prior to removing it. No option for that when right clicked from...
click start click on computer to open then on your drive usually C: to expand you should see your usb drive right click on it you will see an array of options including send to desktop to make short cut also an eject and yes you should always eject it before removing it or use the remove hardware safely ability it's usually in the bottom toolbar you should see it once you connect your usb drive otherwise it wont be there
hope this will help you
Aug 10, 2011 | Western Digital Passport 320GB External...
I have a WD 1TB Hard Drive. The HD shows up in 'safety remove hardware' but not in my computer. I have tried to assign a 'drive letter' to it in disk manager but disk manager is showing the hard drive to...
Try the following steps:
1. right click on my computer and select manage
2. choose Storage-> disk management.
If you say that the drive appears in the "safely remove hardware" than it should appear here too.
Select the hard drive and select "change drive letter and path". Add a drive letter and your hard drive
should appear in my computer.
Feb 11, 2011 | Western Digital WesternDigital Hard Drive...
Using the jump drive device
no it shouldn't crash. you can just pull it out but i guess the "proper" way is to go to MyPC right click it and click eject
Feb 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't see my buffalo usb ministation under my computer
right click on my computer click manage, then in the new screen click on disk management, can you see the device there? if so right click on it and click delete partition, then after right click and make a partition and format it with a quick format, this should then show it in mycomputer ,this will delete all data on the hard drive!
Jul 02, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
WD My Book doesn't show up in My Computer
If yours is like mine it's because someone whipped it without reformatting it. Go to Contorl Panel, System and Maint., Admin Tools, Comp Management, Disk Management. You should see the drive there, but unallocated. Right click on the unallocated portion at the bottom of the screen and choose Simple Volume. Follow the Wisard, choose Quick Format and you've formated your Ex. Hard Drive. It should come up in My Computer now. Congrats!
Mar 15, 2009 | Western Digital My Book Essential Edition...
External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Oct 06, 2007 | Western Digital My Book Essential Edition...
Toshiba Canvio 500 GB USB 2.0 Basics Portable E05A050BAU2XK (Black) Hard Drive Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
