Question about Logitech Z-340 Computer Speakers
I have a logitech z-340 3 speaker set. The problem is that there is a loud hummmm. Can you tell me how to fix it and at what cost. Thank you in advance for any help you can give me. Sincerely..F. Doucette
  • Logitech Master
  • 27,725 Answers
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Mar 16, 2011
Chirping noise
The cost is too great to repair.
Oct 18, 2013 | Logitech Audio Players & Recorders
I am looking for an audio cable that i am missing for a logitech z-340 subwoofer. i have been looking high and low and cant find info on how to get another.... please help.
  • Consumer Sales
    6505 Kaiser Dr.
    Fremont, CA 94555 USA
    +1 800-231-7717
    Monday - Friday, 6:00am - 6:00pm PST
call them and tell them your delema and im sure they will sell you a new one :D
Jan 29, 2011 | Logitech Z-340 Computer Speakers
I have this set, and one of the speakers do not already function? can anyone tell me how to fix it...pls...
It may be the same problem as mine, a dirty volume control. It can be cleaned with contact cleaner, available from radio shack, or any electronics store. You need to pry the front grill off carefully with a flat screw driver, remove 4 screws to gain access to volume pot. Do both speakers work at some volumes?
Mar 07, 2010 | Logitech Z-340 Computer Speakers
Our logitech z-340 speakers are not working and there's no power?
Plug the satellites into the subwoofer, plug the mini jack into your computer, plug it into a wall out, and turn it on.
May 30, 2009 | Logitech Z-340 Computer Speakers
Logitech z-340 speakers
These speakers just plug into your sound output mini-jack. No "speaker" driver is required, just drivers for your sound card. I'll bet those are already installed.
Jan 19, 2009 | Logitech Z-340 Computer Speakers
Need wires for z-340
I just got one too. I guess I'll tear it apart and post the pinout. Also have a set of Altec Lansing satalites (ACS340) with the same connector (hmmmm, Z-340 -- ACS340... probably the same thing they just changed some pins)
I let you know!
Aug 24, 2008 | Logitech Z-340 Computer Speakers
Woofer Quit
Check the pin connection it is loose or the pins may be bent. Check Connection to sub hold it in tight if no pins are bent and see if the hum stops. Hope this Helps it is what was happening to my set>GOOD LUCK>If pins are bent straighten them>
Aug 13, 2008 | Logitech Z-340 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Logitech Z340 Power speaker problem
yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
Nov 04, 2007 | Logitech Z-340 Computer Speakers
Ups and Downs with Logitech
yeah repair the volume switch, open the speaker carefully and pump out the lead which connected the switch and the board..
Oct 11, 2007 | Logitech Z-340 Computer Speakers
Logitech Z-340 Computer Speakers Logo
185 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
