How to detect a leak in A/C coolant. the superheat is at 48F instaed of 20. Please advise me, I can not afford paying 400 dollars for the search
  • 236 Answers
Check if oil is present in the system piping.Or use soap.
Posted on Aug 04, 2008
Approximate cost to replace fuel pump on 2001 Altima Nissan I have 94k milesis it worth fixing
Your asking the wrong questions. The cost for the fuel pump is what it is. Shop around to get the best price. Rockauto for example. Second are you doing the repair or a shop. Replace fuel filter also. Next how is the car is it worth 300or 400 dollars or is it worth 2000. Can you afford to buy a new car or even a 1000 dollar car and pay to get it fixed. 300 hundred to fix the fuel pump is nothing when you think buying a replacement car for thousands. You do the repair yourself you only paying for parts not labor
Jan 28, 2018 | Nissan Cars & Trucks
Tip
Small coolant leak
This is a little easy diy'er for the everyday joe.If you have noticed a small coolant leak coming from your motor area, not a pouring leak but more of a drip,and you don't feel like paying a repair bill of $400, then go to your local neighborhood parts store and purchase a bottle of radiator/coolant stop leak.The best brand I've found is called Bar's Leak, it actually seals up most small coolant leaks within the day.All you do is add this to the coolant in the radiator.I hope this tip helps!!!
on Dec 01, 2009 | Chevrolet Silverado 1500 Cars & Trucks
2001 Honda Cb 400 Super Four coolant leaking
Hi, Bryant for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2001 Honda Cb400 Super Four coolant leaking Google Search
Coolant Leak Answer
Free manuals for honda cb400 super four
http://www.400greybike.com/files/cb400-Superfour-Parts.pdf
Honda CB Owners Manuals
Jan 24, 2013 | 2001 Honda Cb 400 Super Four
Leaking coolant underneath battery from a bolt
Is it coming from radiator or hose engine block?
Jul 04, 2017 | 1994 Honda Accord
2003 Cadillac CTS at 225,000 miles Code P0128 comes up periodically. Any solution other than a thermostat change at $400 plus?
First off who ever said $400 to change a thermostat is trying to rip you off. The actual part is like $20 bucks max and its so easy to change. I can guide you through it if you would like.
The P0128 code is Coolant Thermostat Malfunction.
These are the possible causes for this code:
- Insufficient warm up time.
- Low engine coolant level.
- Leaking or stuck open thermostat.
- Malfunctioning engine coolant temperature sensor.
These are the possible quick fixes:
- Top OFF Engine Coolant
- Replaced Thermostat
Jan 15, 2011 | 2003 Cadillac CTS
Mazda mpv 2002 coolant leaking somewhere. Filled
it also happen to me on a mazda mpv 2000 for years i was adding anitifreeze i found out that the water pump was leaking just do it yourself easy change just pay $60 dollars for it. underneath the car theres a plastic shield the antifreeze will drip and stay there thats why you didn't noticed the leak.
Mar 02, 2010 | 2004 Mazda MPV
Similar issue
dear friend-the warrenty on a clutch is only 20 000 km,therefore you have to pay for the replacement,but 2500 dollars is a bit steep i suggest you get more quotes befor reparing.
Jun 30, 2009 | 2006 Hyundai Tiburon
Radiator hose gone
there are two hoses. one top one bottom. squeeze each one tell you see which one is leaking the antifreeze. the hose is connected with two clamps that you can take off with a screwdriver. the hose cost about tendollars you can do it yourself its easy
May 08, 2009 | 1996 Pontiac Grand Am
Radiator issues
well, 50 50 means half antifreeze and half water. if your tight on money, get straight coolant and mix with water. 50% coolant/antifreeze and 50% water. That's why it's called texaco 50/50. Your paying more for there water then you would out of your faucet. If your not able to fix the leak yourself, take it to a shop. You can spend around $200 in a shop now or $300 in antifreeze over the next year. Your choice but to me it's better to fix now then later. Cuz if it runs dry, motor overheats. Hot motor means scorched piston walls and warpped heads. Meaning around $1400 in repairs if not more. If you can find the leak, I should be able to help you with the process of fixing/replacing neccesary parts. If it's simple enough, you should only need basic hand tools.
Sep 18, 2008 | Chevrolet Suburban 2500 Cars & Trucks
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
