Function of programmable logic circuit - Computers & Internet
  • 71 Answers
A programmable logic controller or programmable controller is a digital computer used for automation of electromechanical processes, such as control of machinery on factory assembly lines, amusement rides, or lighting fixtures. plc are used in many industries and machines. Unlike general-purpose computers, the plc is designed for multiple inputs and output arrangements, extended temperature ranges, immunity to electrical noise, and resistance to vibration and impact.
Posted on Mar 16, 2011
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
I have a LG wd-1025 washing machine and the start button wont work and does this intermittently
REPLACE SWITCH! If the machine persists after replacement then have the programmer checked if it is mechanical and the main logic board if the machine has electronic programming functionality
Jul 31, 2015 | LG Washing Machines
S type non start
The P0670 means "Glow Plug Module Control Circuit"
The P0195 means "Engine Oil Temperature Sensor"
The P0184 means "Fuel Temperature Sensor A Circuit Internittent
The P0383 means "Reserved by SAE J2012
The P0579 means "Cruise Control Multi-Function Input "A" Circuit Range/Performance
Hope that can help you!
____________________
AK500 key programmer
Sep 06, 2012 | 2003 Jaguar S-Type
Torque convertor clutch circuit electrical code po743
CIRCUIT DESCRIPTION
The shift solenoid valve SL is turned ON and OFF by signals from the ECM to control the hydraulic pressure
acting on the lock–up relay valve, which then controls the operation of the lock–up clutch.
DTC No. DTC Detection Condition Trouble Area
P0743
 ECM detects open in solenoid SL circuit 4 times when solenoid
SL is not operated (2–trip detection logic)
 ECM detects short in solenoid SL circuit 4 times when solenoid
SL is operated (2–trip detection logic)
 Open or short in shift solenoid valve SL circuit
 Shift solenoid valve SL
ECM
Fail safe function
If the ECM detects a malfunction, it turns the shift solenoid valve SL OFF
Jun 10, 2010 | 1999 Ford Expedition
How the microprocesser function
Features
  • Microprocessors have become the movers and shakers of our everyday world. We use them in computers, televisions, watches, microwaves and practically every other electronic device. Their micro-size is no reflection of the myriad capabilities these chips possess, ranging from 2 to 3 mm square to maybe an inch thick. Silicon makes up the material of a microprocessor chip. Sliced wafer thin, silicon serves as an ideal conductor and insulator for Function
  • A microprocessor is the central processing unit in a computer. It receives, transmits and coordinates every command and process carried out by the system. Electrical currents, moving through wires and transistors, are converted into usable messages through the use of a Boolean logic language. Based on the "on/off" frequency of current moving through transistor circuits, this Boolean logic communicates system commands to and from receiving devices within the computer. The microprocessor communicates within two primary capacities: logic and the processing of information. These processes are handled by two components within the chip:
    *Arithmetic logic unit (ALU), responsible for all commands requiring an arithmetic or logic function
    * Control unit (CU), which handles the information processing from the computer's memory
  • From these units within the chip, clusters of wires called "bus" lines send and receive information to and from system devices.
  • Oct 16, 2009 | Computers & Internet
    When I try to operate my Go920:Error calling method on NPObject!
    Did you find the solution? I am getting the same with my Go 730
    Sep 19, 2009 | Tomtom ONE v3 Car GPS Receiver
    Computers & Internet Logo
    128 people viewed this question
    David Payne
    David Payne
