Question about Bosch SHE45M06UC Built-in Dishwasher
The water is only filling the bottom of the dishwaher. It is not running through the sprayers
I'm having the same problem, was told to put in an anti sudzing liquid found near carpet cleaners at lowes... Haunt found it anywhere yet. Tried using dishwasher magic, but that didn't work either bc water never left bottom... Have u found a solution?
Posted on Nov 11, 2011
Tuscany kitchen faucet
The hose is always filled with water when not in use. The longer that water remains stagnant in that line, the more it will absorb that smell. Try running the water for 10-15 seconds before filling your glass. If that doesn't solve the problem, purchase a new hose.
Oct 20, 2013 | Plumbing
I have a Kenmore dishwasher, purchased in 2000, it is not cleaning the dishes on the top rack, just happened all the sudden.
You should check to make sure that the lower sprayer is extending to spray the bottom of the top rack and that water is being pumped up to the top sprayer. You will need to take the dishwaher out of the cabinet to test.
Jul 15, 2011 | Kenmore Dishwashers
White film on glasses and plates; I have cleaned tubes and nothing is blocking. is it possible that it is too much calcium/deposits; or a ring/gasket in the bottom sprayer that pre vents the water form...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Jan 01, 2011 | Whirlpool Dishwashers
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Dishwashing powder/liqud will not dissolve
Is your dishwasher filling and draining? The detergent should mix, completely with the wash water and there should be no residue of just detergent. Make certain that the machine is filling and draining properly, otherwise, call the repairman.
Mar 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Sprayers Will not work.
so what is the problem fills but wont spray
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Open Questions:
See all Bosch SHE45M06UC Built-in Dishwasher Questions
Bosch SHE45M06UC Built-in Dishwasher Logo
107 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
