I need to know how to use my new laptop battery correctly.
  • Juanita Vega
    Juanita Vega Mar 16, 2011
    in order to help you better i need to know what your laptop is
  • 71 Answers
Whenever u use your laptop on the battery power then fully use battery till it get down then plug into ac power.this is the proper use of your battery.
Posted on Mar 16, 2011
    Scholar:
  • 115 Answers
The proper way of using the battery is to Initially charge it for for 8 hours. The computer must be off while connected to the ac adapter or charger. Also, fully charge it and use it until it drain. Do not plug the ac adapter overnight while the battery is in it. If you're going to use the laptop as desktop, it is better to remove the battery and use the ac adapter to power ON the laptop.
  • 6,771 Answers
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
  • 24 Answers
The rule of thumb is never use your laptop while charging.
1. Turn off the Laptop. Plug in power core to charge. Leave it for about 8-10 hours.
2. After 8 hour. unplug powder core. Leave it 30 minute for cooling down.
3. Turn on the laptop and use it until batter are almost empty and shutdown automatically
4. Leave it 30 minutes for cooling down.
5. Plug in powder core to charge. Leave it for about 8 hour.
Repeat step 1 to 4 two more times.
Keep in mind that you should avoid using laptop while charging.
With a new motherboard installed, am still having problems with AC power cord and battery. I know battery is getting to end of it's life.Power cord will not power laptop by itself. Laptop will onl
Output of 19 Volts DC at 6.3 Amps is correct. (It isn't the Amperage you have to be concerned about so much. It is the Voltage. Voltage is correct)
Mounted on the motherboard of your laptop is a power correcting chipset.
This chipset senses when the laptop battery needs a trickle charge, or a full charge. It also senses when the laptop is to run straight off of the battery, or the AC adapter. (Charger)
With a Battery being at the end of it's 'Life Cycle', you may be overtaxing this chipset. Can't sense that the laptop needs to run straight off of the AC adapter. Tries to constantly charge the battery.
Replace the Battery.
Or the motherboard isn't worth poo-poo, and has a bad power correcting chipset.
(Don't care if the motherboard is new. Lemons are made)
Some examples of chipset's used in this mode, I am referring to;
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://html.alldatasheet.com/html-pdf/85156/VISHAY/SI4925BDY/183/1/SI4925BDY.html
For additional questions please post in a Comment.
[ Also would like to ask what the diagnoses was, for motherboard replacement ]
Regards,
joecoolvette
Mar 18, 2012 | Toshiba Satellite A75-S2112 Notebook
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
The laptop will only work on the mains cable
1) Check that the battery is correctly and firmly installed
2) If your BIOS has a "battery check" feature, run it
3) Try powering down the laptop for 3 hours while being connected to the charger and see if the battery charges
4) You may need a new battery if it is older than 3 years. You can try by switching it with a friend's battery or buy a cheap one for $20-$60 on eAby or a local computer store (try to locate a non-chain store that buys and sells USED laptops, it may be cheaper)
Good luck and please, let me know if it worked
Alex
Mar 21, 2010 | HP Compaq nx6110 PC Laptop
Battry
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | ASI CL51-15 Notebook
Dell Inspiron E1505 won't recognize new battery
It won't charge or work correctly if it's not the correct one and of the right voltage etc.I don't know how the battery even went in if it's not the Dell specified battery.If it went in and looked to fit maybe the battery itself is bad but its hard to say.
Aug 04, 2009 | Dell Inspiron E1505 Notebook
My battery on lm70 express laptop only charges to 70%.fitted new but same problem.charged in another comp.and charged fine.
How do you know that it has charged to 70% and it is the correct percentage on your Laptop?May be you need some other program that are available on the internet that will tell you the exact charge percentage. Make note that In many ways, lithium-ion is superior to nickel and lead-based chemistries and the applications for lithium-ion batteries are growing as a result. Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.Removing the battery from the laptop when running on fixed power protects the battery from heat. Make sure the AC Adapter that you are using [on both laptops] is supplying the correct voltage and if possible check with Load.
Jul 08, 2009 | Computers & Internet
Dell inspiron b120 laptop won't power up
i dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
Jun 23, 2009 | Dell Inspiron B120 Notebook
Maxdata pro 650t laptop needs a new CMOS battery.
Remove the old battery , the number is imprinted on it . then just have the saleperson at walmart or radioshack match it up , shouldn't be more than 5 bucks.
May 16, 2009 | Computers & Internet
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Battery problem
It could be an hardware problem. I had a similar issue on a dell laptop.
the AC power outlet that was loose. Try to put the power cabel in and see if it moves around. If that is the case you would need a new mother board.
If the power supply is broken, your laptop is not able recived the power. If the PC doesn't get the power it can't charge the battery.
Does the machine behaive as described also when it's plugged into the wall? Becase if this is the case, it can't be a battery related issue. Now, if it does it just when you are using the battery, than you are correct it may be a battery issue.
the battery could be old (battery do no last forever) or maybe it doesnt fits correctly in the machine.
Let me know,
Angela
Aug 29, 2008 | Compaq Presario Notebook
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
