Question about Kenmore Dryers
How to replace a dryer belt in the kenmore special edition dryer model 110. 886629
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: Replacing the belt on my kenmore electric dryer model # 110.8756.
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and clean out the dryer. Oil the wheels and idler. Replace the belt using this diagram . NOTE yours is lower right:
Posted on Dec 22, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Posted on Jan 20, 2009
dragonsthatk
  • 547 Answers
SOURCE: Replace dryer belt
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
My dryer heats up but the drum does not rotate im going to try and see if the belt has broken any other suggestions?
Most likely belt has broken. Once in awhile, the belt will work its way off if you had weird loads like shoes or something. The other likely possibility is the motor. Motors are very simple to replace as well.
Jan 13, 2014 | Dryers
Where do i find belt routing diagrams?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Depending on the model Kenmore you have, you will refer to either diagram H, B, or K. If you have trouble being able to determine which diagram you should use, please post back with your complete MODEL NUMBER so I can assist you further. I hope you find this information helpful.
Apr 21, 2010 | Kenmore 62602 Electric Dryer
Need to replace the dryer belt and have the dryer taken apart, how do i put the belt back on?
Thre are a couple of different ways, the dryer belt goes back on a Whirlpool manufactured dryer (including Kenmore). However, since you posted no MODEL NUMBER, I can only give the following advice:
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to diagram H or K.
If you aren't sure which configuration to use, please post back with your model number, so I can provide you with a more difinitive answer. I hope this helps you.
Jan 21, 2010 | Dryers
I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Oct 23, 2009 | Kenmore 62622 Electric Dryer
Pulley came off dont know how it goes back on
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, there will be a link for "Dryer Belt Diagrams under the "Special Features" section. Scroll down to Kenmore. Since you didn't post a model number, you will have to look at diagrams H, B, or K. If you are confused, please let me know. I hope this helps you.
Apr 07, 2009 | Kenmore 62622 Electric Dryer
Can't get drum belt on Kenmore dryer
Generally belt comes around drum then around pulley tensioner and then back to motor pulley in a zigzag fashion
May 06, 2017 | Dryers
Can't get Dryer Belt on Kenmore Dryer
Not sure if your dryer is the same, but here's a diagram that may help.
Dec 12, 2008 | Roper RAS6233KQ Top Load Washer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
