Question about Car Audio & Video
I have manual windows n i need to take the door panel off passenger front n replace the speaker i cant get the speaker because i dont know what size it is n the window handle is stoping me from taking the panel off to see what size it is
  • 625 Answers
You need a window crank removal tool or...a really small pick tool to remove the horseshoe shaped clip that holds the window crank on. Be careful when removing...it may fly across the room and you'll spend an hour looking for it. Also, go to metraonline.com, enter your vehicle info and the speaker sizes for your vehicle will be displayed.
Posted on Mar 16, 2011
Gmc yukon right door not working
Your solution is a front passenger door module (FPDM),before you replace it check for open fuse in the engine junction fuse box,I dont know the fuse number but it is a 25 amp fuse.8_15_2012_6_16_45_am.gif
Aug 15, 2012 | 2003 GMC Yukon XL
Passenger door removal for radio speaker access.
YOU NEED A DOOR PANEL FLAT TOOL AND WINDOW CRANK CLIP TOOL IF YOU DONT HAVE POWER WINDOWS. A HAYNES REPAIR MANUAL TO SHOW YOU HOW TO REMOVE DOOR PANEL.
Apr 04, 2010 | 2007 Chevrolet Cobalt Coupe
I NEED NEW SPEAKERS FOR MY FRONT DOORS IN MY HONDA CIVIC COUPE 1997 BUT DONT KNOW WHAT SIZE TO BUY?
Not sure if you had a sedan, hatch, or coupe but here is the info you requested. Front door speakers measure 6.5" with a top depth of 1.75" (you have no depth problems here but any larger than 1.75 and you might have to cut out the factory housing.)
If they are door or kick panel speakers, you have to remove that panel to extract the speakers. Then measure them with a ruler; better yet, make a pencil outline of them (outside rim) and also where the mounting holes are. Then, when you buy new speakers say at Best Buy or some such, you will get the proper size, mounting and DEPTH. Unless you want to build all new mounting enclosures, you have to be sure of all the size measurements so that your new speakers will fit.
Wiring them is easy. There should be instructions. Speaker wires do have a + and - side, and if you cross them, the speakers will work but won't sound as good. Also be sure you have the POWER to drive your new speakers. Buy speakers of the same "impedence", measured in ohms right on your speakers.
Also, in here you can find the 1997 Honda Civic Service Manual.
Easy job, good luck (remember rated this help).
Oct 14, 2009 | Honda Civic Cars & Trucks
Passenger side speakers don't play sound
take the passenger door panel off, hook any speaker to see if it works then... may be a problem inside the radio if it dont work when you try this please let me know and rate my answer please..thank you so much
May 16, 2009 | 1998 GMC Jimmy
Changing front door speakers in 1990 Mazda RX-7
The size of speaker that will go into that vehicle is a 6 1/2". You will need to take off the door panel in order to remove speakers. Once door panel is removed, locate screws holding speakers and remove and reinstall new speakers.
May 05, 2009 | 1995 Cadillac DeVille
I dont know which wires are which in the dash of a 1987 dodge dakota
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black/Yellow
Left Rear Speaker Negative Wire (-): Gray
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
May 04, 2009 | Car Audio & Video
Window switch for driver control and passenger switch window
sounds like you have a passenger window motor problem. Try hitting the right door panel hard, down near the speaker opening and pushing the switch at the same time. If it moves, the motor windings are and needs to be replaced.
Mar 26, 2009 | 1999 Mercury Grand Marquis
Speakers
This is a partial solution to let you know that the door panels for both the front and rear speakers have to be removed,, See repair manual for removing the door panels
Dec 15, 2008 | 1999 Volkswagen Passat
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
