Question about Kenmore Dishwashers
Soap suds remains in bottom of dishwasher after completing all cycles
  • 4,323 Answers
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 16, 2011
Why do soap suds remain in the bottom of my Kenmore, model #665.13113K701, dishwasher at the end of a cycle? I have run several cycles without soap and there still are suds remaining.
My guess being I have not physically seen it:
A.Improper install and the system is not draining properly.
B.Clogging in the drain pipe at the sink to the sewage system.
C.Failing draining pump.
D.Water softener issues.
E.Someone you have over is pranking you.
Aug 06, 2014 | Kenmore Dishwashers
I put liquid dish soap--by mistake--in the rinse agent compartment. What can I do?
This is easy to fix, if you know what to do; and we do. First scoop out as much water as you can and dump it in the sink. Next add a cup or two of white vinegar and run the dishwasher for a short time. Now scoop out more water.
The vinegar cuts the foaming action of the soap. You may have to repeat the process to eliminate the suds because some soapy water remains inside the pump and hoses.
Also, if you poured it into the soap dispenser, wash that out by hand to get all the dish soap out.
It has happened many times in the past, and will certainly happen many times in the future. Someone pours dish soap in the dishwasher and all hell breaks loose. I can imagine many parents have had their kids do this type of thing and had to battle the outcome. I wish I could blame it on my unborn child but unfortunately, it was I, that poured dish soap into the dishwasher. Before moving on, look below at the images and get a good laugh. Alright, now that you have gotten that out of your system. Here are some ways to help get the suds to go away.
  • Sprinkle table salt onto suds.
  • Drop ice cubes into bottom to cool the water.
  • Scoop out as much water/suds that you can.
  • Try a cup or two of white vinegar.
    You may need to run it through the cycle 3 or 4 times to get the suds out completely. After the second cycle, my suds decreased pretty significantly. The second picture below is my wife's idea of a funny picture. Who ever said getting to the back of the dishwasher was easy?
    Thanks for contacting Fixya.
  • Jul 03, 2009 | Dishwashers
    My Smsung dishwasher always has suds in the bottom after cycle has completed
    Couple of questions?
    1. do you have a water softener?
    2. what type of detergent are you using and how much?
    3. is the detergent HE rated?
    To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
    Sep 17, 2012 | Samsung DMT300RFS Builtin Dishwasher
    Frigidaire dishwasher leak
    run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
    Sep 02, 2012 | Frigidaire Dishwashers
    Dishwasher not draining completely-suds left
    Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
    Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
    Suds are left in the bottom after the cycle
    Suds should not be present in a dishwasher. Automatic dishwasher soap is not suppose to suds at all. If you do have suds it is from some soap like a hand washing or dawn that got in there by mistake.
    To clear it out pour some vinegar or cooking oil in the bottom and run the dishwasher for about 5 minutes, then cancel. If the suds are not gone repeat.
    Apr 30, 2010 | KitchenAid Dishwashers
    Water won't empty. the bottom remains full
    check to see if the water is draining completely. let it fill then drain and cancel unit check to see if this works if not check the drain pump. might also you will want to check soap,alot of times you can add jet dry and lets say a cascade with jet dry shine sometimes can over suds a machine this will cause the unit to keep rinsing to get the soap out,so when it finally ends there is extra water in unit. it is called over sudzing. let me know if my tip helped you.
    Feb 23, 2010 | Dishwashers
    Soap suds and some water not draining out of washer after cycle is complete
    if you read the manual, it states that this is normal. so dont let this bother you
    May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
    The dishwasher was full of soap suds but most of the water drain
    Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
    Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
    Hope this helps!
    Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
    My bosch dishwasher gets stuck in wash mode. We have to turn the dial to move to the next cycle. When we check inside soap suds are built up on the bottom. We use less than a 1/2 of an Electrasol tablet,...
    Have you checked it is draining properly? Partially-blocked drainage would likely be detected and cause the dishwasher to stop mid cycle, with soap suds left behind. I would check (1) the drain filters inside the dishwasher and (2) that the hose is not kinked (3) that all the S-bends etc where the dishwasher hose connects to the drain under the sink are clear.
    Jan 30, 2018 | Dishwashers
    Dishwashers Logo
    187 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
