55" RCA HDTV STD. HEARD POP, NOW SCREEN HAS CONCAVE EFFECT, YOU CAN SEE RED AND BLUE AT EACH SIDE OF SCREEN OVER LETTERS. THIS SET IS UNDER 1 YR AND ACCORDING TO SELLER (Wal Mart) it should be under warranty.
Sounds like you have some bad convergence IC's not allowing the colors to line up properly.
Posted on Feb 11, 2009
I heard a "pop".
HD50LPW62 is Not projection,Projection TVs have 3 Tubes R/G/B.
Your TV is DLP which has Lamp and Color wheel, Ballast board, Lamp Fan.
You need to Check the Lamp,You will need to remove the back in order to see the Lamp.
Lamps are easy to replace.
Mats Electronics has Lamps 1-800-628-1118
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 04, 2009 | RCA HD52W59 HDTV Projection Television
Picture in concave on all sides and blue and red are off
The shape of the picture indicates that the convergence circuit is not working properly. Generally speaking this occurs without making any sound at all. The popping you heard may have been a capacitor in the power supply. If the power line effected supplied the convergence circuit, repairing the supply should return the set to normal. If not, then the convergence ICs may be faulty. If you can solder, and are confortable working inside the set where potentially dangerous high voltages exist (even when unplugged), you may be able to repeir this yourself.
Let me know and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | RCA P52960 52" Rear Projection Television
Screen lookes like colores separating
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
