Question about Gigabyte GA-EP45-UD3R Motherboard
Fan does not come on - Gigabyte GA-EP45-UD3R Motherboard
  • Gigabyte Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Posted on Mar 16, 2011
    Problem Solver:
  • 16 Answers
Try plugging in the fan into a different fan header to test to see if it functions. Also it may not turn on right away.
How to replace coolig fan sending unit on a 2008 chevy uplander
Why ? Did you test ? Hook up a scan tool to see if the PCM/ECM - engine computer is reading coolant temp. ? Testing not guessing ? Do you even know how the system works .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed fan relay, which is Fan 1 Relay, through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from Fan 1 Fuse 29 through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the Series/Parallel relay, which is the Fan 2 Relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM supplies a ground path for the high speed fan relay, which is the Fan 3 Relay, and the Series/Parallel through the high speed cooling fan relay control circuit. This energizes the Series/Parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the Fan 3 Relay coil is energized, the relay contacts close to provide battery positive voltage from Fan 2 Fuse 33 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
Feb 27, 2017 | 2008 Chevrolet Uplander
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Relay Driven Dual Cooling Fan Diagnostics
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Where to buy replacement fan blades
    everywhere Christine!
  • replacement fan blades ' eBay www.ebay.ca > Search > replacement fan blades Find great deals on eBay for replacement fan blades and replacement ceiling fan blades. Shop with confidence.
  • Replacement Fan Blades - Plastic & Aluminum Fan Blades ... https://www.grainger.com/category/fan-blades-and-propellers/hvac... Keep air circulating with replacement fan blades and propellers from Grainger. Get what you need to renew or repair broken fans, condensers and air circulators.
  • Amazon.com: replacement fan blades: Tools & Home Improvement www.amazon.com > Search > replacement fan blades Online shopping from a great selection at Tools & Home Improvement Store.
  • Fan Blades & Arms - Ceiling Fan Accessories - Ceiling Fans ... www.homedepot.com > ... > Ceiling Fan Accessories Shop our selection of Fan Blades & Arms in the Lighting & Ceiling Fans Department at The Home Depot.
  • Aluminum Fan Blades - GlobalIndustrial.com www.globalindustrial.com > HVAC/R & Fans Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Aluminum Fan Blades - www.globalindustrial.ca www.globalindustrial.ca/c/hvac/parts/fan-blades Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Replacement Fan Blades - MSCDirect.com www.mscdirect.com > ... > Fans > Fan Accessories & Replacement Blades Discover Fan Accessories & Replacement Blades and other Fans at MSC Industrial Supply. Over 1 million products that ship and deliver fast.
  • ceiling fan blades ' eBay www.ebay.ca > Search > ceiling fan blades Find great deals on eBay for ceiling fan blades and ceiling fan replacement blades. Shop with confidence.
  • Ceiling Fan Blades Replacement - Price Comparison - Canada www.shopbot.ca/ceiling-fan-blades-replacement/price/canada/593664 Ceiling Fan Blades Replacement - Find the Lowest Prices in Canada. Shop Smart with Reviews, Advice and Prices. Shopbot is Canada's Favorite Price Comparison Site!
  • Ceiling Fan Blades ' Replacement Fan Blades ' ATG Stores www.atgstores.com > ... > Fans > Ceiling Fan Parts & Accessories Shop ceiling fan blades & replacement fan blades at ATGStores.com, a Lowe's store. We carry top brands including Monte Carlo, Hunter Fan, & Fanimation.
  • Feb 18, 2016 | Dryers
    Gettining error 57.03 in hp laserjet 5200 printer
    57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
    1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
      • x = 1: FM1 (Laser/Scanner Fan)
      • x = 2: FM2 (Power Supply Cooling Fan)
      • x = 3: FM3 (Formatter Fan)
      • x = 4: FM4 (Face Down Deliver Fan)
    2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
      • Fan 1 J208
      • Fan 2 J216
      • Fan 3 J210
      • Fan 4 J225
    3. Replace the faulty fan motor.
    Dec 22, 2010 | HP Office Equipment & Supplies
    I own a 2003 Dodge Durango. The coolant fan stopped working. I found a plug loose near the fan. Is it possible it came unplugged? If yes, then is the plug inside the fan case? I have looked all over and...
    I couldn't find the plug or wire on the diagram on my online resource, either. The fan must have a cable going to it to operate, somehow, though, I agree.
    Engine Cooling Fan Removal & Installation To Remove:
    1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
    2. Remove or disconnect the following:
      • Fan blade/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front - threads on viscous fan drive are right hand. CAUTION
        Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
        Do not unbolt fan blade assembly from viscous fan drive at this time.
      • Upper fan shroud attaching hardware
      • Upper fan shroud and fan blade/viscous fan drive from vehicle CAUTION
        Do not place viscous fan drive in horizontal position after removal because silicone fluid in the viscous fan drive could drain into its bearing assembly and contaminate lubricant.
      • Four bolts securing fan blade assembly to viscous fan drive.
    To Install:
    1. Install or connect the following:
      • Fan blade assembly to viscous fan drive.
        1. Torque to: 17 ft. lbs. (23 Nm)
      • Fan blade/viscous fan drive assembly and upper shroud into vehicle
      • Fan shroud retaining screws
      • Fan blade/viscous fan drive assembly to water pump shaft
      • Negative battery cable
    Sep 30, 2010 | 2003 Dodge Durango
    I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
    Engine Fan REMOVAL & INSTALLATION 3.8L Engines
    1. Disconnect the negative battery cable.
    2. Remove the radiator upper sight shield.
    3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
    4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
    5. If necessary, remove the air bag crash sensor.
    6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
      Fig. 3: Remove the fan from the engine 86873117.jpg
      Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
    7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
    8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
    4.6L Engine
    1. Loosen the fan clutch-mounting shaft from the water pump hub.
    2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
    3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
    4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
      Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
    5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
    6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
    7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
    5.0L Engines
    1. Loosen the fan clutch-to-water pump hub retaining bolts.
    2. If necessary, remove the drive belt from the water pump pulley.
    3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
    4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
    5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
    7. Install the fan and clutch assembly and the fan shroud.
    8. Install the fan clutch-to-water pump hub bolts.
    9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
    10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
    11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
    Jul 14, 2010 | 1995 Lincoln Continental
    1999 jeep grand cherokee laredo is engine fan belt driven or electric?
    The radiator cooling fan used on the 4.0L engine is
    an hybrid fan design. The hybrid fan system consist
    of a low speed viscous driven mechanical fan and a
    electrical fan.
    The hydraulic fan used on vehicles equipped the 4.7L engine, replaces both the electric fan and the engine driven mechanical fan. The hydraulic cooling fan is integral to the fan shroud and is located between the radiator and the engine. The power steering pump supplies the hydraulic fluid and pressure to rotate the cooling fan blade, while the electrical part of the fan is controlled by the JTEC. The hydraulic fan drive (motor) consists of the three major components:
    - Steering flow control valve
    - Fan control valve
    - Two stage G-rotor hydraulic drive
    The hydraulic fan and drive is not serviceable.
    Therefore any failure of the fan blade, hydraulic fan
    drive or fan shroud requires replacement of the fan
    module because the fan blade and hydraulic fan drive
    are matched and balanced as a system and servicing
    either separately would disrupt this balance.
    Oct 29, 2009 | 1999 Jeep Grand Cherokee
    Need to take off fan clutch, have taken off parts in the way
    4.9L SFI
    SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
    Removal
    1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
      Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
    1. Remove two screws retaining fan shroud.
    1. Remove the fan blade (8600), fan clutch and shroud.
    1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
    5.0L, 5.8L and 7.5L Engines
    Removal
    1. Remove screws retaining fan shroud (8146) to radiator (8005).
    1. Remove four screws retaining clutch on water pump hub.
    1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
    1. Remove four screws and separate fan clutch from fan blade.
    Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
    Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
    Gigabyte GA-EP45-UD3R Motherboard Logo
    32 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Tony
    Matthew Spark
    Matthew Spark
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
