Question about Maytag Kitchen Ranges
My Maytag gas range model MGS5770 has a fault code of F9. What does that mean?
  • 213 Answers
SOURCE: F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Posted on Nov 27, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag gas range model MGR5750ADW
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Posted on Sep 28, 2008
Dipu007
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
EllaWatson25
  • 725 Answers
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Posted on Jan 18, 2010
Maytag MGS5770 Gas Kitchen Range display is out. And no spark to top burners, and fan in back runs constantly.
Must be a bad oven control. Looking at the wiring diagram I see a hot wire from the power terminal to the fan and onwards into the ovencontrol. Must be a fried relay on that control board. Ya might want to remove the control and look for signs of failure.
Oct 16, 2011 | Maytag MGS5770 Gas Kitchen Range
MAYTAG OVEN SHOWING A F9 CODE. I PRESS THE CLEAR BUTTON, AND A FEW SECONDS LETTER THE CODE APPEARS AGAIN. WHAT IS CAUSING THIS CODE. OVEN WAS USED EARLIER AND HEATED JUST FINE.
Hi rosebud1239,
The F9 fault code error description is about the door latch. Please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MGS5770 Gas Kitchen Range
What is an F8 error code meaning? Thanks!
From this website ::
http://www.ehow.com/facts_7597003_maytag-range-error-codes.html
Codes "F0," "F1," "F5," "F6," "F7," "F8" and "F9" are all various errors with the Maytag electronic range control, or ERC. The errors are various faults with the ERC and a replacement part is needed for the range.
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) More info, let me know. Charlie
Jul 26, 2011 | Maytag MER5775Q Electric Kitchen Range
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
STOVE CODE FLASHING
f9 depicts a door lock error
3 specifies the latch lock lower sensor
Mar 01, 2009 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
F9 code
F9 - Door latch supervisory (door latched) - Unlock door and check switches or clock assembly (also called the ERC)
Nov 21, 2008 | Maytag MGR5770 Gas Kitchen Range
Nov 26, 2007 | Kitchen Ranges
Kitchen Ranges Logo
18 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
