Question about Samsung ML-2570 Laser Printer
Samsung ML-2571N Laser Printer - paper jammed around roller
My Samsung ML-2571N laser printer has a piece of paper jammed on the roller. It has rolled itself around the roller and I cannot remove it. I haven't been able to locate a repair manual anywhere on the net to see how to access it. The roller is in the top part of the machine, next to the reddish-orange one (heating?).
Any assistance you can provide me would be GREATLY appreciated.
Ken Davies
  • mariamasif99
    mariamasif99 Jul 14, 2012
    i also have same problem ..the site which is advised by CATALIN TURCU is not available now..please tell me the solution.??? i have to print imp documents
  • Samsung Master
  • 4,924 Answers
Http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_cd=ML-2571N/XAA&mode=C
this link will guide you to the site with the user guides...but in short ..all ya have to do is to be careful and to open and remove the paper...there are not many things that may be damaged in the process...but there is a certain order you have to follow in doing it ...and a few devices that has unusual safety removing gadgets...
Posted on Jun 13, 2009
Green and red leds are blinking
Hi
Try turning the printer off and on.
Clear any paper jam on the machine.
Disconnect it from the power supply and then re-connect it after a while.
Feb 27, 2012 | Samsung ML-2571N Laser Printer
I cannot free the paper in the jam in my samsung laser printer ML-1640/ml-2240 model
place a piece of card stock in the fed tray. turn on the printer and manually assist the card stock between the rollers. you may need to turn the printer off and on several times before it comes out the exit and moving the jam out.GL
May 02, 2011 | Office Equipment & Supplies
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Paper will not feed
Open the front cover and pull out the cartridge and you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Aug 17, 2010 | Samsung ML-2571N Laser Printer
Paper jammimg in our ML 1430 Laser Printer
clean the roller opening the door at the backside of printer...................and if u want our technician support contract us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Samsung ML 1430 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Paper feed problem
It sounds to me like there is still a small bit of paper or something stuck in the printer causing the concertina effect on the paper. If you cant do it yourself, then you need someone to take the printer apart to clear any debris
Dec 15, 2008 | Samsung ML-2571N Laser Printer
Samsung ML-2570 Laser Printer Logo
399 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
