Question about Mitsubishi WS-65809 65" Rear Projection Television
WS 65809 skematics??
Is there anywhere I can get the skematics to find the horizontal output transistor?????? I need the product # for it.... People on Ebay have them listed but I don't if they would work or if /i need a certain one for the tv.. Can you help me out with this?????
  • Mitsubishi Master
  • 8,617 Answers
Horizontal out put is Q5A31 for your model its a 2SC5418
Posted on Aug 02, 2008
I have a Mitsubishi ws-65809, the tv won't power
I presume you unplugged the set and redid the check:
2,3 is deflection circuit problem (probably in Horizontal sweep circuit) and can be almost anything---check output transistors and look for cracked or bad cap in that area.
The error code is only a general indication of the kind of problem and this one is like saying car will not start etc.
Mar 18, 2012 | Mitsubishi Televison & Video
Mitsubishi WS-65809 convergence problem
I know these sets very well and have posted instructions here for the chip replacement many times.
If you really need help I am in California and will be online noon until 11 pm tomorrow- (Pacific time) if you really want help post a question in the Premium section here attention SD TECH and I will help you more.
SD TECH
Jan 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi ws-65809 when i turn it on it shuts down after 2 seconds, i held the input and menu buttons in and it gave me cod 2-3 was wondering what could be the problem, and if it is an easy fix...
Error code 23 means "Loss of Horizontal Deflection" that means horizontal section of TV is not working. Cause can be horizontal out transistor is short or not getting +B volts from power supply.
If you understand schematic, I can email you complete repair manual of Mitsubishi WS-65809 that will help you to diagnose problem by measuring volts and checking parts.
Thanks.
Sep 15, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws-65809 error code 23
Your symptom of the code 23 sounds like a problem in the Horizontal circuits of your television.
Troubleshooting this circuit is very tricky as there are a good many components that control the Horizontal circuit. It could be as easy as a shorter Horizontal Output Transistor, (I highly doubt it). Most likely you have lost the horizontal pulse or you may have an open horizontal drive transistor.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
I have a Mitsubishi CS-3125R that displays a horizontal line with sound. I suspect the horizontal transistor is out and cannot find one. Any ideas?
You are misleading yourself. When you have a horizontal line across the screen it means that the vertical circuit is not working. You see, the vertical circuit moves the beam up and down which is not happening. The horizontal circuit moves the beam left and right and it is working. Your set probably needs a new vertical output IC and some electrolytic capacitors that work with it. The caps dry up with time and harm the output IC.
Jun 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Horizontal output transistor
no not expensive at all from repair man but if you attempt it yourself you could damage serton components
Jul 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
i do not recommend that you do it your seft
Jul 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
The error codes...
a 2 3 code means horizontal deflection has stopped thats what is most likely shutting down your set. The most probable cause for this would be a defective Horizontal output transistor.
Jul 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
