Question about Hobart Dishwashers
I have a top tech 500 dishwasher it has er then 09 on the display screens I don't have an instruction manual to look up the error codes
5 Suggested Answers
SOURCE: Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Posted on Aug 18, 2006
SOURCE: dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Posted on Nov 21, 2008
SOURCE: 4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Posted on Jan 22, 2010
SOURCE: Frigidaire PLD4375RFC Dishwasher error "ER s" any
error message says ou-what does that mean?
Posted on Apr 23, 2011
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
I GET ERRO CODE E32 ON MY MODEL #ER-A405T AND NEED TO FIND OUT WITCH KEYS I MUST PRESS TO ASSIGN A CLERK #
I think you mean an ER-A450T. Try pressing 1 then CASH# button (usually next to the JOURNAL FEED button. Not the CA/AT button)
If anyone needs a Sharp ER-A450T manual, try this page:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Apr 02, 2010 | Casio Parts Cash Register PC Desktop
Er...error code
FREE FIX!! Before you do anything else try this....
Blinking display with "ER S" on this model is a "keypad error" NOT a control board error. It occurrs when a button on the keypad is "stuck" for more than a minute most likely from being corroded - which can happen when the steam accumulates on the underside of the counter and drops down onto keypad (an apparent design flaw which frigidaire will do nothing about) - all the techs I've talked to recommend replaceing the entire plastic keypad assembly (oem part cost $125 at my local store). But they sell just the switch that is glued into the assembly for 16$ at www.repairclinic.com and it is a thin plastic film with electronic circuits running through it. Before you buy it though, turn power off at breaker, then try gently prying the keypad switch cover (the strip with the buttons on it) off of the top of the door panel (It is stuck down with a double sided clear tacky strip - I did it with a thin butter knife) and cleaning off any corrosion on underside of strip and on switch. Gently replace the keypad cover strip and press down around the edges gently. Then turning power back on to machine and see if that fixes it - worked for me - FREE!!! Worth trying before you call out a tech
Mar 22, 2010 | Frigidaire PLD4555RFC Dishwasher
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwasher er error code
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
103 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
