Question about NCR Office Equipment & Supplies
My nrc printer cable uses five wires but was splice in the middle the oher side is a cat 5e cable what colors do i use on the cat5e cable
3 Suggested Answers
rosener
  • 103 Answers
SOURCE: How do i connect my printer with a usb to a Ethernet (RJ45) cable
Hi Tony,
I assumed you'd like to share the printer on network. I recommend to buy a printer server device that will connect USB port of printer and that device has RJ45 port that can be connected to router or switch hub to share the purpose. Hope this gives you an idea.
Best regards,
Rosener
Posted on Jan 31, 2008
SOURCE: how to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Posted on Jul 18, 2009
How to create a network ?? using five computers ? what are the things that i need to know please help me...
for this the hardware you need is CAT 5E cable , rj45 connectors, crimping tool, a 8 port network switch, make straight combination in cat5e cable, then connect one side to the switch and other to the pc do this in all the systems, after that run the network setup wizard thats it
Jul 26, 2011 | Computers & Internet
Hello I need to hardwire a tripplite n001-010-bl catse cable to a belkin cat5e keystone jack bel-r6d024-ab5e I do not know the correct wiring configuration to do this. Please advise?
The wiring is done as if you are building your own CAT5e wire. See the following URL: http://www.beginnercode.com/2006/11/09/connecting-network-cable-ends/ . There are other sites. As long as both ends are the same the cable will work (unless you want a crossover connection).
For a PDF version see: http://www.n-tron.com/pdf/cat5ecableschemes.pdf .
I hope this helps.
(Keystone jacks for ethernet come in two types: plug in RJ-45 and punch down the individual wires with the tool. All of the punch down jacks came with a diagram, had the wire arrangement indicated on the unit, and a cheap plastic punch down tool.)
Jan 17, 2011 | Tripp Lite TRIPPLITE N001-010-BL Snagless...
Rewiring a house putting in a net work for the future . what cable cat5e ,cat5e screened , cat6 , cat6 screened . would cat5e screened be better than cat6 unscreened ? cables away from mains ,
I'm guessing when you say screened and unscreened you mean shielded or unshielded. Shielded wire is used when there is a higher possibility of electrical or RF interference. In a typical household those type of interferences are uncommon. As far as the Cat.5e or Cat. 6 decision, Cat 5e is tested to 150 Mhz. compared to a 250 Mhz. rating on Cat. 6 therefore with future speeds in mind I'd go with the Category 6.
Aug 25, 2010 | Dynex 7' Cat 6 Network Cable - Gray
Cat5e Single Socket RJ45 Ethernet Network Face Plate
My preference is to use the T-568b if there is not already a standard where you are doing the installation at. The A and B are just different standards to terminate an ethernet cable.
TIA/EIA-568-A, T-568B RJ45 Wiring Standards
To answer your question..If you want a straight through connection you would use T-568B (or T-568A) at both ends of the cable.
T-568B T-568A
Pin Color Pin Name Color Pin Name
1 Orange Stripe Tx+ Green Stripe Rx+
2 Orange Tx- Green Rx-
3 Green Stripe Rx+ Orange Stripe Tx+
4 Blue Not Used Blue Not Used
5 Blue Stripe Not Used Blue Stripe Not Used
6 Green Rx- Orange Tx-
7 Brown Stripe Not Used Brown Stripe Not Used
8 Brown Not Used Brown Not Used
Dec 31, 2009 | Cat5e Cat.5E Connection Box (512114)
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
100 Ft. Cat 5e Cable damaged
I suggest soldering them, it is real easy and I could walk you through how but it would still work if you twist the together and elecrtical tape them off. Also were at on the cat 5 is it exsposed? If it is near the end you could just put a new plug on it.
Mar 18, 2009 | Cat5e 100 Ft. Cat 5e (100FTCAT53)
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
How to wire up a cat5e faceplate with cat 5e wire
Mar 07, 2008 | Computers & Internet
22 people viewed this question
Top NCR Office Equipment & Supplies Experts
k24674
Are you a NCR Office Equipment and Supply Expert? Answer questions, earn points and help others
