Question about Xerox XG-91D 19" LCD Monitor
Unplugged my computer for 3 weeks. Plugged it back in, monitor powered up with the Xerox logo and nothing else. Now it won't power on after I tried turning if off and on...any suggestions?
    Scholar:
  • 82 Answers
First be sure that the problem is with your monitor and not with your computer, try plugging in a different monitor to the computer or a different computer to the monitor to isolate the problem. Often when leaving computers sitting for weeks at a time dust can build up in them that can cause fans to jam and computers to not operate correctly. Try dusting out your computer with some canned air dusters. If the problem is with the monitor it will likely need to be returned. Hope this helps!
Posted on Mar 16, 2011
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
My Acer TCO03- power button is just blinking but no picture display
Blow hot air into the back with a hair dryer before trying to start it.
(not kidding)
if that works, one of the capacitors on the power board went bad.
even if that does NOT work, one of the capacitors on the power board went bad.
It is ALWAYS one of the capacitors on the power supply gone bad.
Being unplugged for a few weeks - as you stated - drained it of "juice", and it just cr*pped out. It was going to fail soon, in any event.
Fixing it can cost you less than a dollar, if you Google for information.
Best of luck!
Mar 03, 2015 | Acer Monitor Lcd 19in Al1923 0.29mm...
My monitor displays analog rgb then goes to blank black screen?
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Xerox Computers & Internet
My sa200 will not turn back on
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | Samsung SyncMaster SA200 Series 19in LED...
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
Montior will not come on
internal board on the lcd has blown capacitors you will need to replace those on the power board to bring the monitor back up.
Nov 22, 2008 | Star Logic 17" LCD Monitor
Won't power on. Screen is black.
I have added a sort of solution on this site. The monitor has a 3 years manufacturers warrantee on it. Goodies Enterprise Ltd of Bedford will fix it for 56GBP including shipping. They've just fixed mine and its cheaper than buying a new one. 3 months guarantee on repair.
Nov 02, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
42 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
