LG WM2277HB - i had to replace the MAIN PWB ASSEMBLY due to the PLAY button not working anymore. i have the correct part for the MAIN PWB and it is connected and working, however, i cannot get the knob off of the old one to put it on the new one. any suggestions? thanks! sheri
4 Suggested Answers
  • 156 Answers
SOURCE: Will not spin at all.
also the factory has determined that the main board can cause all the problem as long as the water draining out it be the main board
Posted on Feb 25, 2008
  • 16 Answers
SOURCE: LG WM2277HB drum wobbles when doing larger loads.
You could have a broken strut. However, keep in mind that these units are designed for 16llbs of dry weight for optimal performance.
Posted on Dec 07, 2008
SOURCE: LG Washer (WM2277HB) won't turn on without unplug & plug in again
I'm having the same problem!!! ANY solutions out there?
Posted on Sep 13, 2010
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
Wont turn (spin) gives le code...sort of works wirh no load... Not at all with a load...
LE = LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY. • The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable. • The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited). • The hall sensor is out of order/defective.
Dec 18, 2010 | LG WM-2277HW Front Load Washer
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
My LG washer keeps displaying LE error and shuts down. What is wrong with it?
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
Nov 20, 2009 | LG WM-2277HW Front Load Washer
I own a lg washer le has poped up on dig. screen tub will not spin ...
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced, as well as the sensor
Aug 18, 2009 | LG Washing Machines
My LG washing machine will not run through washing cycle
Locked motor error (LE)
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
***. If the hall sensor is defective, replace the entire motor.
Jul 13, 2009 | LG WM1814CW Front Load Washer
Lg washing machine trips out and displays le on screen. WM2277HS
LE= Locked Motor Error
Here are the causes
circuited).
Aug 17, 2008 | LG Washing Machines
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
