Question about Cell Phones
FRecently purchased GS290, put old sim in and have not been able to retrieve memory from sim card. New phone has old number, and is working but cannot access old contacts and messages. I also am not able to connect to facebook, so am not sure how to go about that either?
  • 314 Answers
Hi fragglewise ,
what i suggest for you to do is insert the sim card into your old phone and transfer all the contacts into the sim card. after that insert the sim card into your new phone and find the option wher eyou can copy the contacts in the sim into your phone.
if that does not work then that means the sim card cannot store contacts.
another option is to place the sim card in your old mobile and write down all the numbers that you NEED on paper and then later type it all down on the new phone.
i hope this helps, good luck!
Posted on Mar 16, 2011
How do I clear all personal data, before returning the phone?
Many Mobile Telephones give an option to record personal numbers etc. into the phone memory or onto the SIM card. The SIM card often has more memory and this should be the chosen option. If you remove your SIM you should be able to access the telephone memory and see what is in it. Delete all the personal information, there should not be much on it. If you find that all your personal data is saved to the telephone, you should be able to save the information to the SIM, then remove the SIM and delete the data on the phone. If you are keeping the same number and same SIM, then your personal data will be available on your new phone. If you are changing your service provider and getting a new phone, by putting your old SIM into the new phone you can transfer the SIM data to the new phone and then onto the new SIM. After you should destroy the old SIM by cutting it up through the Electronic Chip. If you have to send it back send it in pieces.
The more modern android type phone will have an option to connect with a PC to recover your data. Alternatively, you might be able to email the data to yourself. After which you will need to either delete all personal stuff if you don't have a memory card in the phone. If you have a memory card just remove it and install it into your new phone, all your data should be there.
Bob.
Jan 09, 2016 | Samsung SCH-I545 Galaxy S4 16GB Verizon...
Phone has died and I need my phone contacts
The only option in this case is to have the phone repaired and retrieve the numbers by transferring it into your sim.
Aug 18, 2008 | LG CU400 Cellular Phone
I have an LGL75C with new sim card and cannot switch apps from phone memory to sim card
Do you mean from internal memory to SD card?Some apps can not be moved to SD cards.Also if you replaced your sim card the apps are on the old card.You would have to backup your apps from the old sim card to the external SD card then re-install them.Some cell providers have online back up that you can use.Good luck.
Mar 13, 2013 | Cell Phones
How to get unlock code (nck) for my lg gs 290 model mobile? imie number is 354106045479299
To get the unlock code for the LG GS290 (Cookie Fresh) you can visit the site Theunlockspot.com buy the NCK code and unlock it...you can enter the code using the instructions below:
LG GS290 Cookie Fresh Unlocking Instructions Warning : Do not enter any wrong unlock codes on your LG GS290 Cookie Fresh mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GS290 Cookie Fresh mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG GS290 Cookie Fresh with its ORIGINAL SIM Card.
2 - Enter 2945#*290#. An unlock menu will be displayed.
3 - Enter the unlock code.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GS290 Cookie Fresh.
Sep 21, 2011 | Cell Phones
I transferred all the phone numbers from my old sony ericsson cell phone to my sim card, but cannot figure out how to copy all the sim numbers onto my new sony ericsson vivas pro.
To transfer your contacts through the SIM card:
  1. Copy your contacts from your old phone to your SIM card. If you need help with this, please consult the old phone user guide.
  2. When the copying is done, move the SIM card to your new phone.
  3. Select Menu > Contacts.
  4. If the phone asks you to copy info from the SIM card, skip steps 5-10.
  5. Otherwise, tap Options > Settings > Contacts to display.
  6. Select SIM memory > OK, then tap Back.
  7. Tap Options > Mark/Unmark > Mark all.
  8. Tap Options > Copy > Phone memory.
  9. Tap Options > Settings > Contacts to display.
  10. Select Phone memory > OK, then tap Back.
Feb 28, 2011 | Sony Ericsson Vivaz Cell Phone
Move numbers to my new phone without reentering the numbers
Not a problem. Follow the following process to do it.
1. Copy all your contacts/numbers from your old phone memory into the sim card memory.
2. Turn off the phone and take the sim card out.
3. Insert the sim card into your new phone and copy the contacts/numbers from sim card to phone memory.
Hope it helps for you.
Please let me know if you need further assistance.
Thanks !!
Nov 09, 2010 | Motorola Mobility i880 Cellular Phone
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
How can I retrieve the phone number?
Please copy all the contacts on the phone memory of N70 to the sim memory first and then copy the phone numbers from the sim to the new samsung phone.... Hope i solved ur querry.
Jan 03, 2009 | O2 Samsung SGH-E250 Cellular Phone
My old LG cell phone (LGCU400) broke and was replaced with a newer model (LGECU515). I put my old sim card in the new phone but I cannot retrieve any of my contacts/info from the sim card. Is there...
Hello!
I went to the AT&T/Cingular store and they tried hooking my broken phone to their system but could not retrieve any #s (they were saved to my phone not my SIM). They told me there was no other way to retrieve the #s and that a computer cable wouldn't work bc their system would've been able to retrieve them. I knew there had to be some way of retrieving them bc I could still turn my phone on- the top 1/2 (screen) had just broken off.
It finally dawned on me to look at my husband's phone (we had the same one), write down the buttons to press & the # of clicks per button on my old phone, in order to blindly go through my entire contacts list and save each one to my SIM card. Approximately every 25 contacts I saved I'd switch the SIM card to my new phone and make sure they were all saving correctly. I'm currently still transferring all 137 contacts- grueling but well worth it. This only works if your old phone will still turn on & function even if you can't see/use the screen.
***Make sure your phone's saving your contacts to your SIM and not your phone- I thought mine was and it was one rude awakening today when I found out otherwise! I hope this helps!
Apr 22, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
