Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Need a wiring diagram. The fan on/off switch came apart. I need to wire around the switch. Need full internal wiring diagram. Thanks for your help and assistance. Guy Sparkman 420 Haden St. Tyler, Tex. 75701 guysparkman@suddenlink.net
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
we have a hampton bay fan burning smell coming in didnot run
Posted on Jul 07, 2008
SOURCE: Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Posted on Feb 19, 2009
I have just fitted a ceiling light, as instructed, but the light will not switch off by the light switch
Most ceiling fans are factory wired so that the light is independently controlled from the fan, therefore when you turn on/off the wall switch it has no control over turning the light on or off.
However, the light can be wired, inside the fan unit, so that it works in conjunction with the fan, so that when you turn the wall switch on or off, it will turn both the fan and light on or off together.
To do so would require the specific wiring diagram of how the fan unit is presently wired. It's a simple modification, but without knowing or seeing how it's wired (internally) it's impossible to tell you which wires need to be modified and reconnected.
Nov 02, 2014 | Home
Need a internal wiring diagram for a Casablanca Fan P4M55H
I don't think you can do that if it came with a built-in receiver.
Jul 07, 2014 | Casablanca Fan P4M55H Cosmopolitan...
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
My air conditioner/heater blower will not work on the 4th setting. Setting 1,2, and 3 do work. I have replaced fan speed switch and replaced the resistor. Any ideas?
You'll have to find the correct wiring diagram in order to trace down the fault in your system.. Once you obtain the wiring diagram you'll be able to see what else beside wire is between the #4 speed setting and the blower motor. My guess is you might find a high speed fan relay is triggered from the #4 fan switch setting, applying full battery voltage to the blower motor. If locating the appropriate diagram proves to be difficult you can try looking around the underhood and passenger compartment fuse panel to find a relay. Keep in mind not all relays are always in fuse boxes which makes the diagram important.
Sep 10, 2010 | Pontiac Bonneville Cars & Trucks
I'm trying to install a used Shell Electric Manufacturing (Holdings) Co. LTD. model U42 ceiling fan, however it appears that the internal wiring has been moved around and in some cases cut off. I am...
the black rectangle is a capacitor! there is no diode in a ceiling fan, usually the white wire is the common or neutral , the blue is for lighting and the black one is for the fan
Mar 10, 2009 | Dryers
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
71 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
