Question about Systemax Venture PC Desktop
Can't boot from CD. When I attempt to boot from the CD I get the screen that says "Boot from CD" and the flashing cursor unfortunatly my mouse and keyboard are not enabled so I can't tell it to boot. If I boot without the CD it will proceed past the Welcome Screen and my Key Board and Mouse work but all I'm able to do is get the Task Mgr so I can tell it to Restart or Shut Down. I've tried another USB port and another Key Board but that doesn't help. I'd gladly re-Install the whole OS if I could. Any suggestions would be welcome. Thanks.
    Scholar:
  • 82 Answers
Keyboards and mice that use the USB interface will require drivers to operate and therefore not work before Windows has loaded. If you can, run the CD from the "My Computer" window, but it sounds like you are having problems, so you should go somewhere with cheap or old electronics (frys electronics, Charity store) and get a keyboard or mouse with a P2 connector , which is recognizable as a round green or purple (sometimes not colored) connector with (I believe) 9 pins on it. Hopefully your computer has the connections for these on the back (likely above other connectors), these will work before the computer has loaded Windows. Hope this helps.
Posted on Mar 16, 2011
DC7600 Wont boot from win 2003 CD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Hope this helps
Dec 09, 2012 | HP DC7100 PC Desktop
Why do not restored disks work for Acer Aspire M1100?
Turn off the computer Henry then turn it back on and hold down the alt key and tap F10 and make sure you remove any disks from the CD drive.
It would appear that the hard drive is having boot sector issues.
http://www.ezsystemrepairs.com
Nov 08, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
Ntldr is missing at startup
To fix your problem please follow the below steps.
1. Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
2. Restart your computer.
3. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer.
4. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
5. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
Thanks for contacting Fixya. Have a good day.
Aug 10, 2011 | Dell Dimension 4600 PC Desktop
Just installed windows 7 with an external cd/dvd and now it will only boot with the cd/dvd attached. otherwise a black screen appears with the cursor in the top left corner.
when it boots to a flashing cursor in the top left corner and everything else it working, this means that it is NOT finding the operating system on the hard drive, many times due to boot sector issues.
Make sure you set your hard drive to main or first startup device.
Jun 05, 2010 | ASUS Eee PC 900 PC Notebook
Did a heavy 17.4 Gig data transfer from external to c/drive... Ccleaned and shut down... Went to boot up system less than an hour later, and reached the aforementioned result: Windows won't boot (black...
You may have transferred a boot partition or file to the c drive. The first thing to do is remove all external devices and start up and enter BIOS settings. Find the boot menu and make sure the internal HD is recognized and enabled and is listed first in boot device sequence. If it checks out but still won't boot, the safest thing to do is remove the drive and mount it in a live machine using a USB adapter AFTER the live machine is already booted. You can then backup the contents before attempting any recovery or other changes. If another system can't mount the drive, it may be corrupted or defective. There is a program available called Partition Recovery which is very good. It is downloadable and inexpensive, and can be burned as a bootable CD from a live system. If you boot your machine with this CD, you can usually recover a corrupted HD partition fairly easily. If the HD has failed mechanically or electrically, you have little choice but to send it to a shop to attempt data salvage.
Dec 17, 2009 | Dell Computers & Internet
HP Pavilion ZD8000 No CD Boot
replace the ODD and try with another cdrom.
Jun 09, 2009 | HP Pavilion zd8000 Notebook
Black Screen
try booting from a cd like the reinstall cd for windows that came with the computer. when starting hit F12 to show 1 time boot menu; select cd drive; hit any key when asked to boot from cd. This will tell you if its a software or hard drive problem.
Feb 18, 2009 | Dell Inspiron 1525 Notebook
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Systemax Venture PC Desktop Logo
203 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
