Question about Poulan Garden
I need to put a mulching kit on a poulan pxt175g42
4 Suggested Answers
  • 95 Answers
SOURCE: Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Posted on Sep 06, 2009
  • 93 Answers
SOURCE: poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
Posted on Sep 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Transmission is very Jerky when starting to move
Hi and welcome to FixYa, I am Kelly.
Your model has this Transaxle.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0702050-00001.png
I suspect that the gears item 14 are worn. Possibly the larger gear item 15 also.
You have little alternative but to remove the transmission and then the top of the transmission to inspect the gearing. Due to the number of gears in this transmission... the symptom that you have can be an accumulative problem from wear on multiple gears. Items 14 and 15 are the main causes.
parts:
http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Riding-mower-tractor-Parts/Model-PXT175G4296016002400/1324/1509200/P0702050/00001?blt=06&prst=&shdMod=
Download this manual it will be extremely helpful. (5.21 mb 124 pages)
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_Transaxle_Service_Information.pdf
Make sure to check the short internal drive chain for slack and wear. This too can cause jerky operation.
Thanks for choosing FixYa,
Kelly
Posted on May 07, 2011
What size blade duds it take
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Jun 17, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
What type mulch kit do I get. One says stamped deck zoom 34
Mulch kits are a waste of money. If you have high lift mulching blades you keep the grass in the deck long enough to do the desired cutting. Open the deflector and block it open with a bungee strap and let the blades spread the grass,so you get no streaking or wind rowing.
CAUTION
Always discharge away from PEOPLE and Buildings and automobiles. I cut an acre here that looks like any golf course with NO MULCHING KIT. MULCHING BLADES ONLY.
Oct 19, 2009 | Garden
Poulan push mower question
Sep 06, 2009 | Poulan "Poulan" Push Mower
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Craftsman 6.5 lawnmower
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
sean
Apr 28, 2008 | Craftsman Computers & Internet
Garden Logo
227 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
